Author Topic: switching to OpenBox desktop envoriment and setting it up.  (Read 653 times)
Offline KamenkoTV
  • New Linux user still learning
  • Peppermint version(s): 9, 10
« on: August 19, 2019, 10:48:28 am »
hello im new linux user!!
i have a question Peppermint 10 os is based on LXDE desktop envoriment witch have some parts of OpenBox so how do i install clear looking openbox desktop envoriment with sandard openbox menu and how to setup OpenBox.???
Re: switching to OpenBox desktop envoriment and setting it up.
« Reply #1 on: August 19, 2019, 11:48:51 am »
Peppermint does NOT use LXDE, we only use a couple of components from LXDE (lxappearance & lxsession), so we don't use Openbox.
« Reply #2 on: August 19, 2019, 01:36:11 pm »
Hi KamenkoTV,
It is very easy, nevertheless, to install and set up Openbox in Peppermint 10. I suggest, however, the even lighter weight and very similar Fluxbox. I use both of them, but find myself using Fluxbox much more often. I have a tutorial explaining the configuration files for Fluxbox that you can find in this link on the forum.   ;) It is perhaps a bit dated, but the basic information about Fluxbox is still very useful. Peppermint 10 flies with Fluxbox. Give it a try -- if you like Openbox better, then just remove Fluxbox and install Openbox8)
