Author Topic: Serial to USB (SOLVED)  (Read 981 times)
Re: Serial to USB
« Reply #15 on: August 22, 2019, 12:26:03 pm »
That's the answer Mark
I changed the Serial line from /dev/ttyS0 to /dev/ttyUSB0 in PuTTY and off it went
You have no idea how happy you've made me :)
All I have to do now is figure out how to save these settings in PuTTY
Many thanks
Re: Serial to USB
« Reply #16 on: August 22, 2019, 12:29:53 pm »
You're more than welcome Graeme .. can't help you with the PuTTY config saving though, I've never used it :)
I'm sure it'll be online somewhere, so if ya get stuck give us a shout and we'll see what we can find.
« Last Edit: August 22, 2019, 12:51:14 pm by PCNetSpec »
Re: Serial to USB
« Reply #17 on: August 22, 2019, 01:20:47 pm »
Thanks again Mark
I figured out how to save and load a session so were good to go, another application he won't need Windows for, up to this point we've got him about 80% Linux, if it wasn't for his accountant insisting on VT Transactions we'd have had him 100% Linux (hopefully with the help of the smart guys at WINE HQ we might get that sorted out as well in time)
So another one bites the dust, nothing left but to mark this solved
Thanks again
« Last Edit: August 22, 2019, 11:17:35 pm by emegra »
Re: Serial to USB (SOLVED)
« Reply #18 on: August 22, 2019, 02:37:32 pm »
The other option might be him insisting on his accountant using something else .. or a new accountant.
There's something wrong with a world where the people YOU pay make the stipulations ???
