Author Topic: Trouble uninstalling mono  (Read 291 times)
Offline Boola
« on: August 15, 2019, 08:47:15 am »
Hey Guys!
I installed monodevelop + mono but had really much trouble uninstalling them but they seem to be gone now. I still get some weird error messages when using the update manager and using the console "sudo apt upgrade" command.
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be REMOVED:
  libglade2.0-cil libglib2.0-cil libgtk2.0-cil
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 2 948 kB disk space will be freed.
Do you want to continue? [Y/n]
When i press Y and enter i get:
(Reading database ... 401549 files and directories currently installed.)
Removing libglade2.0-cil (2.12.45-0xamarin17+ubuntu1804b1) ...
rm: cannot remove '/usr/share/cli-common/packages.d/policy.2.4.glade-sharp.installcligac': No such file or directory
dpkg: error processing package libglade2.0-cil (--remove):
 installed libglade2.0-cil package post-removal script subprocess returned error exit status 1
Removing libgtk2.0-cil (2.12.45-0xamarin17+ubuntu1804b1) ...
rm: cannot remove '/usr/share/cli-common/packages.d/policy.2.8.gtk-sharp.installcligac': No such file or directory
dpkg: error processing package libgtk2.0-cil (--remove):
 installed libgtk2.0-cil package post-removal script subprocess returned error exit status 1
Removing libglib2.0-cil (2.12.45-0xamarin17+ubuntu1804b1) ...
rm: cannot remove '/usr/share/cli-common/packages.d/policy.2.10.glib-sharp.installcligac': No such file or directory
dpkg: error processing package libglib2.0-cil (--remove):
 installed libglib2.0-cil package post-removal script subprocess returned error exit status 1
 libglade2.0-cil
 libgtk2.0-cil
 libglib2.0-cil
E: Sub-process /usr/bin/dpkg returned an error code (1)
How can i remove this annoying messages? And why does it show?
Thank you :).
Re: Trouble uninstalling mono
« Reply #1 on: August 15, 2019, 09:42:51 am »
Try reinstalling them first
sudo apt-get install --reinstall libglade2.0-cil libglib2.0-cil libgtk2.0-cil
then purging them
sudo apt-get remove --purge libglade2.0-cil libglib2.0-cil libgtk2.0-cil
any errors ?
Offline Boola
« Reply #2 on: August 15, 2019, 11:34:38 am »
Thanks for your reply!
I get this when trying the first command:
[sudo] password for alexander:
Reinstallation of libgtk2.0-cil is not possible, it cannot be downloaded.
Reinstallation of libglade2.0-cil is not possible, it cannot be downloaded.
Reinstallation of libglib2.0-cil is not possible, it cannot be downloaded.
Do you want to continue? [Y/n] Y
 libglade2.0-cil
 libgtk2.0-cil
 libglib2.0-cil
Any thoughts?
« Reply #3 on: August 15, 2019, 12:28:33 pm »
You seem to have non-default versions of those packages installed.
can you post the output from:
dpkg -l | grep 2.0-cil
cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; done
Offline Boola
« Reply #4 on: August 15, 2019, 01:52:47 pm »
gives me:
iH  libglade2.0-cil                          2.12.45-0xamarin17+ubuntu1804b1                 amd64        CLI binding for the Glade libraries 2.6
iH  libglib2.0-cil                           2.12.45-0xamarin17+ubuntu1804b1                 amd64        CLI binding for the GLib utility library 2.12
iH  libgtk2.0-cil                            2.12.45-0xamarin17+ubuntu1804b1                 amd64        CLI binding for the GTK+ toolkit 2.12
gives me:
# deb cdrom:[Peppermint 9 (20190102) - Release amd64]/ bionic main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://archive.ubuntu.com/ubuntu bionic main restricted
deb-src http://archive.ubuntu.com/ubuntu bionic multiverse restricted main universe #Added by software-properties
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu bionic-updates multiverse restricted main universe #Added by software-properties
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu bionic universe
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic universe
deb http://archive.ubuntu.com/ubuntu bionic-updates universe
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://archive.ubuntu.com/ubuntu bionic multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic multiverse
deb http://archive.ubuntu.com/ubuntu bionic-updates multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse #Added by software-properties
# deb-src http://se.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu bionic partner
deb-src http://archive.canonical.com/ubuntu bionic partner
deb http://archive.ubuntu.com/ubuntu bionic-security main restricted
deb-src http://archive.ubuntu.com/ubuntu bionic-security multiverse restricted main universe #Added by software-properties
# deb-src http://security.ubuntu.com/ubuntu bionic-security main restricted
deb http://archive.ubuntu.com/ubuntu bionic-security universe
# deb-src http://security.ubuntu.com/ubuntu bionic-security universe
deb http://archive.ubuntu.com/ubuntu bionic-security multiverse
# deb-src http://security.ubuntu.com/ubuntu bionic-security multiverse
** /etc/apt/sources.list.d/danielrichter2007-ubuntu-grub-customizer-bionic.list:
deb http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
# deb-src http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
** /etc/apt/sources.list.d/danielrichter2007-ubuntu-grub-customizer-bionic.list.save:
** /etc/apt/sources.list.d/ermshiperete-ubuntu-monodevelop-bionic.list:
deb http://ppa.launchpad.net/ermshiperete/monodevelop/ubuntu bionic main
# deb-src http://ppa.launchpad.net/ermshiperete/monodevelop/ubuntu bionic main
** /etc/apt/sources.list.d/ermshiperete-ubuntu-monodevelop-bionic.list.save:
** /etc/apt/sources.list.d/google-chrome.list:
### THIS FILE IS AUTOMATICALLY CONFIGURED ###
# You may comment out this entry, but any other modifications may be lost.
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
** /etc/apt/sources.list.d/google-chrome.list.save:
** /etc/apt/sources.list.d/microsoft-prod.list:
deb [arch=amd64] https://packages.microsoft.com/ubuntu/19.04/prod disco main
** /etc/apt/sources.list.d/microsoft-prod.list.save:
** /etc/apt/sources.list.d/mono-official-vs.list:
** /etc/apt/sources.list.d/mono-official-vs.list.save:
** /etc/apt/sources.list.d/nordvpn.list:
# NordVPN releases, stable
deb https://repo.nordvpn.com/deb/nordvpn/debian stable main
** /etc/apt/sources.list.d/nordvpn.list.save:
** /etc/apt/sources.list.d/peppermint.list:
deb http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic main
# deb-src http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic main
deb http://ppa.launchpad.net/peppermintos/p9-respin/ubuntu bionic main
# deb-src http://ppa.launchpad.net/peppermintos/p9-respin/ubuntu bionic main
** /etc/apt/sources.list.d/peppermint.list.save:
Offline Boola
« Reply #5 on: August 16, 2019, 11:10:38 am »
I just reinstalled my PC, way easier :).
« Reply #6 on: August 16, 2019, 04:32:25 pm »
Okay, was just about to respond .. but the nuclear option always works too :)
