Author Topic: Windoze app on Peppermint 10.  (Read 924 times)
Offline Birger52
« on: August 11, 2019, 04:36:28 am »
Hi.
New to linux, new to Linux (have tried before, but never found a version I could actually use), new to Peppermint.
Got things pretty much where I want them.
In addition I need to be able to play GW.
So I tried installing Wine as per https://www.pcsteps.com/10463-install-wine-linux-mint-ubuntu-run-windows-apps/
It ends with this msg:
Følgende pakker har uopfyldte afhængigheder:
 winehq-stable : Afhængigheder: wine-stable (= 4.0.1~cosmic) men den bliver ikke installeret
E: Kunne ikke korrigere problemerne, da du har tilbageholdt ødelagte pakker.
Roughly Translated:
The following packages has unresolved dependencies:
 winehq-stable : Dependencies: wine-stable (= 4.0.1~cosmic) but it is not being installed
E: Could not correct problems, as you have detained defect packages.
Why doent the installation simply fetch the packages it needs? Or how do I allow/instruct it to do so?
Is Wine the right thing to use for peppermint 10? (assume it is as Peppermint is derived from Ubuntu).
Thx.
Re: Windoze app on Peppermint 10.
« Reply #1 on: August 11, 2019, 10:10:10 am »
suggests you have enabled the wrong repositories.
Can you post the contents of your
xed /etc/apt/sources.listand the output from:
ls /etc/apt/sources.list.dand
dpkg -l | grep wine
« Last Edit: August 11, 2019, 10:12:59 am by PCNetSpec »
Offline Birger52
« Reply #2 on: August 12, 2019, 04:17:25 am »
xed /etc/apt/sources.list:
# deb cdrom:[Peppermint 10 (20190514) - Release i386]/ bionic main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://dk.archive.ubuntu.com/ubuntu/ bionic main restricted
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://dk.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://dk.archive.ubuntu.com/ubuntu/ bionic universe
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic universe
deb http://dk.archive.ubuntu.com/ubuntu/ bionic-updates universe
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://dk.archive.ubuntu.com/ubuntu/ bionic multiverse
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic multiverse
deb http://dk.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://dk.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
# deb-src http://dk.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu bionic partner
# deb-src http://archive.canonical.com/ubuntu bionic partner
deb http://security.ubuntu.com/ubuntu bionic-security main restricted
# deb-src http://security.ubuntu.com/ubuntu bionic-security main restricted
deb http://security.ubuntu.com/ubuntu bionic-security universe
# deb-src http://security.ubuntu.com/ubuntu bionic-security universe
deb http://security.ubuntu.com/ubuntu bionic-security multiverse
# deb-src http://security.ubuntu.com/ubuntu bionic-security multiverse
deb https://dl.winehq.org/wine-builds/ubuntu/ cosmic main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ cosmic main
deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ bionic main
ls /etc/apt/sources.list.d:
peppermint.list  peppermint.list.save
dpkg -l | grep wine:
nothing...
Terminal:
**@** ~ $ xed /etc/apt/sources.list
(xed:3529): Gdk-CRITICAL **: 13:05:17.734: gdk_window_get_window_type: assertion 'GDK_IS_WINDOW (window)' failed
**@** ~ $ ls /etc/apt/sources.list.d
**@** ~ $ dpkg -l | grep wine
If so the procedure at https://www.pcsteps.com/10463-install-wine-linux-mint-ubuntu-run-windows-apps/ is wrong....
« Reply #3 on: August 12, 2019, 05:01:54 am »
It's not that their procedure is wrong it's that you've added the wine repos TWICE, once for 'cosmic' (which is wrong) and once for 'bionic' (which is right because Peppermint 10 is based on Ubuntu 18.04 aka. bionic).
Run:
gksudo xed /etc/apt/sources.listREMOVE these two lines:-
SAVE the file and close the text editor.
Back in the terminal run:
sudo apt-get updateto update the package cache information.
Now do you get any errors from:
sudo apt-get install --install-recommends winehq-stable -y?
« Last Edit: August 12, 2019, 06:26:21 am by PCNetSpec »
Offline Birger52
« Reply #4 on: August 13, 2019, 01:32:52 pm »
That did the trick.
Thank you so much.
There were more than one place the 'cosmic' version was referenced.
Once cleared out, wine installed just fine - and so did GW.
So again: Thank you very much!
« Reply #5 on: August 13, 2019, 04:26:53 pm »
You're most welcome, glad I could help :)
Offline Birger52
« Reply #6 on: August 15, 2019, 06:40:47 am »
Well...
Had a problem (Still have) with Imageviewing.
Thought display driver might be the reason, so changed to the one recommended and written by the manufacturer (NVIDIA)
Peppermint never recovered from that.
So had to start over.
Followed the same tutorial, and did the same mistake.
and it should then be fairly easy to follow the same correctional path.
It does however now want to install a bionic InRelease - not the bionic main ...
« Last Edit: August 15, 2019, 06:51:28 am by Birger52 »
« Reply #7 on: August 15, 2019, 06:44:52 am »
it MUST be edited with elevated privileges .. so:
gksudo xed /etc/apt/sources.listif that doesn't work, what's the output from:
namei -om /etc/apt/sources.list
« Last Edit: August 15, 2019, 06:47:25 am by PCNetSpec »
Offline Birger52
« Reply #8 on: August 15, 2019, 06:57:48 am »
It was my bad - and I figured that out. YAY!
But it now wants to install a version "bionic InRelease" not the "bionic main" it says in the source.list.
Havde:1 http://ppa.launchpad.net/peppermintos/p10-release/ubuntu bionic InRelease
Havde:2 http://dk.archive.ubuntu.com/ubuntu bionic InRelease
Havde:3 http://dk.archive.ubuntu.com/ubuntu bionic-updates InRelease
Havde:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
Havde:5 http://dk.archive.ubuntu.com/ubuntu bionic-backports InRelease
Henter:6 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease [6.257 B]
Fejl:6 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease
  Følgende signaturer kunne ikke verificeret, da den offentlige nøgle ikke er tilgængelig: NO_PUBKEY 76F1A20FF987672F
Indlæser pakkelisterne... Færdig
W: GPG-fejl: https://dl.winehq.org/wine-builds/ubuntu bionic InRelease: Følgende signaturer kunne ikke verificeret, da den offentlige nøgle ikke er tilgængelig: NO_PUBKEY 76F1A20FF987672F
E: Arkivet »https://dl.winehq.org/wine-builds/ubuntu bionic InRelease« er ikke underskrevet.
N: Opdatering, fra et sådant arkiv, kan ikke udføres sikkert og er derfor deaktiveret som standard.
N: Se apt-secure(8)-manualsiden for detaljer om arkivoprettelse og brugerkonfiguration
Can I start this whole thing over, somehow?
« Reply #9 on: August 15, 2019, 09:38:19 am »
The problem now is simply a missing GPG key.
Run:
wget -q https://dl.winehq.org/wine-builds/winehq.key -O- | sudo apt-key add -enter your password when prompted.
Now try
sudo apt-get updateand the error should be fixed
Offline Birger52
« Reply #10 on: August 16, 2019, 01:58:06 am »
Yes.
Thank you again.
« Reply #11 on: August 16, 2019, 01:49:08 pm »
No problem :)
