Author Topic: Wubi for Peppermintos?  (Read 890 times)
Offline donnielbell
« on: August 09, 2019, 02:32:15 pm »
Is there a way to install wubi to install Peppermintos on a windows machine as a Windows program?
Sent from my LG-M150 using Tapatalk
Re: Wubi for Peppermintos?
« Reply #1 on: August 09, 2019, 04:56:41 pm »
Not that I know to...
There is this
https://www.lifewire.com/wubi-linux-installation-program-2201175
but I doubt it'll work with Peppermint.
Nor would I really advise it anyway, WUBI installs were a pain in the a** to fix if anything went wrong (usually loosing ALL data), so you'd get no support with it from us I'm afraid.
Offline Brianrh
« Reply #2 on: August 10, 2019, 02:55:13 am »
I wasn't sure what Wubi so Googled it and found this:
https://github.com/hakuna-m/wubiuefi/releases
I don't know if this helps, it's all a bit technical for me.
