Author Topic: add mount command to a launcher?  (Read 1002 times)
« on: August 07, 2019, 04:48:37 am »
I'm trying to add the command
sudo mount -a
before
nemo &U
to make sure my network shares are mounted when I click on my Files launcher. How do I get the mount command to run automatically with elevated privileges like that?
Re: add mount command to a launcher?
« Reply #1 on: August 07, 2019, 05:56:48 am »
Well this can be done by adding your commands to a script, then allowing that script to be run without having to enter a password by adding a line similar to:-
username ALL= NOPASSWD: /path/to/your/script
to /etc/sudoers (after backing it up of course).
That script (and ONLY that script) should no longer prompt for a password, if run with:
sudo /path/to/your/scriptso it's run with elevated privileges (meaning you can drop 'sudo' from its contents)
But wouldn't it be easier to just automount your network shares at bootup via /etc/fstab ?
Actually because you're using mount -a I'm guessing you've already added them to fstab but they're not automounting for some reason ?
What's the contents of your
xed /etc/fstab? .. maybe we can fix the entries.
DO NOT add the
nemo %Uline to that script, unless you also want nemo to be started with elevated privileges.
So basically, create a file at say /home/murraymint/my-mountall.sh with the contents
#!/bin/bash
mount -a
save the file, then make it executable with
sudo chmod +x /home/murraymint/my-mountall.shnow create another script at say /home/murraymint/my-mountall-nemo.sh with the contents
#!/bin/bash
sudo /home/murraymint/my-mountall.sh &
nemo %U
make that executable
sudo chmod +x /home/murraymint/my-mountall-nemo.shnow running that second script with
/home/murraymint/my-mountall-nemo.shshould do what you want.
Hope that made sense.
« Last Edit: August 07, 2019, 06:24:45 am by PCNetSpec »
« Reply #2 on: August 07, 2019, 03:36:41 pm »
Yes, the network comes up quite late after reaching the desktop so this fails. I've been trying most of what you suggest but I need to go over it again to see why it didn't work yet.
« Reply #3 on: August 08, 2019, 09:07:01 am »
What are the contents of your
xed /etc/fstab?
I also think I may have misunderstood what you were attempting to do before.
I take it you mean you're trying to edit the "Command:" line in a panel launcher ?
If "sudo mount -a" works after you reach the desktop, it might be better to just create a script that runs that, and autostart that script.....
What's the output from:
sudo cat /etc/sudoersand
whoami
« Reply #4 on: August 08, 2019, 06:02:39 pm »
xed /etc/fstab?
Exactly, I should have made that clear.
I've been trying to do that without success. Which user runs the autostart scripts?
whoami[/quote]
$ whoami
tom
« Reply #5 on: August 08, 2019, 06:05:07 pm »
The workaround now works, with the panel launcher  :)
I used your idea of two scripts so the sudo would only apply to the mount command. I had to use the full path for Nemo to my home directory because &U wasn't recognised when run from the launcher script.
« Reply #6 on: August 08, 2019, 07:23:21 pm »
As you can now use /usr/bin/netmnt to mount your drives without a password, another solution would have been to leave the launcher as default .. then to create an autostart .desktop file to run it after the desktop starts
Make sure
xed /usr/bin/netmntcontains just
#!/bin/bash
mount -a
then create an autostart file
xed ~/.config/autostart/netmnt-autostart.desktopwith these contents
[Desktop Entry]
Type=Application
Name=netmnt-autostart
Comment=Autostart the netmnt script
Exec=bash -c "sleep 5 ; sudo /usr/bin/netmnt"
Terminal=false
That should run 'sudo /usr/bin/netmnt' 5 seconds after the desktop comes up .. I added the 5 second delay to make sure networking had fully come up by that point.
An even better solution might be to simply change your fstab enties from:
192.168.1.21:/mnt/video   /home/tom/Videos   nfs   auto,nofail,noatime 0 0
192.168.1.21:/mnt/4TB /home/tom/Music        nfs     auto,nofail,noatime   0   0
to
192.168.1.21:/mnt/video   /home/tom/Videos   nfs   noauto,x-systemd.automount,x-systemd.device-timeout=10,timeo=14,x-systemd.idle-timeout=1min,rsize=32768,wsize=32768,intr,noatime 0 0
192.168.1.21:/mnt/4TB /home/tom/Music        nfs     noauto,x-systemd.automount,x-systemd.device-timeout=10,timeo=14,x-systemd.idle-timeout=1min,rsize=32768,wsize=32768,intr,noatime 0 0
which works for me.
« Reply #7 on: August 09, 2019, 03:52:19 pm »
Strangely enough they won't mount at all with your options. mount -a throws up no errors, they just never appear. I had to put fstab back the way it was.
