Author Topic: P10 5.0 kernel and rtl8812au-dkms failed.[SOLVED]  (Read 1030 times)
« on: August 04, 2019, 10:28:40 am »
Hello all, I have a little keyboard jig I do with every kernel update.
Accept the new kernel update >
sudo apt-get remove rtl8812au-dkms >
sudo apt-get install rtl8812au-dkms > Normally then I would
sudo modprobe rtl8812au but this time the reinstallation returned:
Error! Bad return status for module build on kernel: 5.0.0-23-generic (x86_64)
Consult /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/make.log for more information.
here's the last few entries from that log file:
« Last Edit: August 06, 2019, 12:11:25 pm by spence »
& '18 Asus VivoBook
Re: P10 5.0 kernel and rtl8812au-dkms failed.
« Reply #1 on: August 04, 2019, 10:30:35 am »
Here's the related inxi -Fz:
& '18 Asus VivoBook
« Reply #2 on: August 04, 2019, 10:41:13 am »
Might try a newer ver: https://is.gd/hamNI4
n/m looks like you have the latest ver  :)
Looking at the first step (and shooting from the hip) I think I would use:
sudo apt purge rtl8812au-dkms
« Last Edit: August 04, 2019, 11:04:44 am by VinDSL »
« Reply #3 on: August 04, 2019, 01:16:12 pm »
just noted the update for dkms @PCNetSpec did my little remove/reinstall jig and still came up with:
Loading new rtl8812au-4.3.8.12175.20140902+dfsg DKMS files...
Building for 5.0.0-23-generic
Building initial module for 5.0.0-23-generic
& '18 Asus VivoBook
« Reply #4 on: August 04, 2019, 01:19:00 pm »
redid this unintstall/reinstall jig again with your suggestion @VinDSL... :
« Last Edit: August 04, 2019, 02:00:09 pm by spence »
& '18 Asus VivoBook
« Reply #5 on: August 04, 2019, 02:07:51 pm »
decided to flip back to the previous 4.18.0-25-generic kernel to get wifi working @PCNetSpec & @VinDSL...  perhaps the reinstall threw up some maybe revealing bits?
& '18 Asus VivoBook
« Reply #6 on: August 05, 2019, 11:42:37 am »
Well that seems to have built the module for BOTH kernels successfully.
Have you tried booting into the 5.0 kernel again and checked if wireless works ?
If not, post the output from:
sudo lshw -C networkand
rfkill listand
iwlist scan
« Reply #7 on: August 05, 2019, 06:29:40 pm »
Booted into 5.0 kernel, wifi dongle doesn't connect...
  *-network
       product: Ethernet Connection (2) I219-V
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: enp0s31f6
       version: 00
       serial: 70:85:c2:29:10:c2
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.2-4 ip=192.168.1.4 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:124 memory:df100000-df11ffff
rfkill list returns nothing
iwlist scan
enp0s31f6  Interface doesn't support scanning.
& '18 Asus VivoBook
« Reply #8 on: August 05, 2019, 06:58:42 pm »
What happens if you (in the 5.0 kernel)  run:
sudo modprobe rtl8812au?
« Reply #9 on: August 06, 2019, 12:03:43 pm »
What I have always used previously:
spence@antec ~ $ sudo modprobe 8812au
[sudo] password for spence:
modprobe: ERROR: could not insert '8812au': Exec format error
and now:
spence@antec ~ $ sudo modprobe rtl8812au
modprobe: FATAL: Module rtl8812au not found in directory /lib/modules/5.0.0-23-generic
spence@antec ~ $ inxi -Fz
System:    Host: antec Kernel: 5.0.0-23-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: desktop Mobo: ASRock model: H270M Pro4 serial: N/A
           UEFI: American Megatrends v: P2.50 date: 03/16/2018
CPU:       Quad core Intel Core i7-7700 (-MT-MCP-) cache: 8192 KB
           clock speeds: max: 4200 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz 4: 800 MHz
           5: 800 MHz 6: 800 MHz 7: 800 MHz 8: 800 MHz
Graphics:  Card: Intel HD Graphics 630
           Display Server: x11 (X.Org 1.20.4 )
           drivers: fbdev (unloaded: modesetting,vesa)
           Resolution: 1920x1080@77.00hz
           OpenGL: renderer: llvmpipe (LLVM 8.0, 256 bits) version: 3.3 Mesa 19.0.2
Audio:     Card Intel 200 Series PCH HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k5.0.0-23-generic
Network:   Card: Intel Ethernet Connection (2) I219-V driver: e1000e
           IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 2391.5GB (1.8% used)
           ID-1: /dev/nvme0n1 model: Samsung_SSD_960_EVO_250GB size: 250.1GB
           ID-2: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
           ID-3: /dev/sdb model: Hitachi_HTS54756 size: 640.1GB
           ID-4: /dev/sdc model: WDC_WD5000AACS size: 500.1GB
           ID-5: USB /dev/sde model: CBO_CardReader size: 1.0GB
Partition: ID-1: / size: 46G used: 41G (96%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A
Info:      Processes: 228 Uptime: 3 min Memory: 705.8/31870.1MB
« Last Edit: August 06, 2019, 12:05:52 pm by spence »
& '18 Asus VivoBook
Re: P10 5.0 kernel and rtl8812au-dkms failed.[SOLVED]
« Reply #10 on: August 06, 2019, 12:13:10 pm »
Whatever update you rolled and sent out earlier arrived and all is now well with the 5.0 kernel and rtl8812au wifi dongle @PCNetSpec !!!
 8)
& '18 Asus VivoBook
