Author Topic: Cursor Randomly Jumps When Using Synaptics Touchpad (SOLVED)  (Read 590 times)
Offline completeidiot
« on: August 02, 2019, 09:01:17 am »
The title says it all.
Whenever I enable touchpad, writing becomes a chore, as all of a sudden, the cursor will jump a couple of lines up (or something). It may not sound so bad, but it's really, really annoying and it breaks the flow of your work frequently.
I have searched the internet for solution, but I haven't found anything useful.
Open to try anything  :'(
« Last Edit: August 02, 2019, 01:06:39 pm by completeidiot »
Offline clatterfordslim
Re: Cursor Randomly Jumps When Using Synaptec Touchpad
« Reply #1 on: August 02, 2019, 09:34:51 am »
It's all to do with vibration, I had the same problem what Laptop are you using? I had same on my Lenovo yoga 500, but that comes with the option to switch off Touchpad and use a proper mouse. I also managed to switch off Touchpad in my Elitebook with a little app called Touchpad Indicator link below on how to install it and use it. I set mine up to be off all the time on start up.
http://ubuntuhandbook.org/index.php/2018/04/install-touchpad-indicator-ubuntu-18-04-lts/
I hope this helps?
This should work in Peppermint 8 too so ignore the 18.04 part
« Last Edit: August 02, 2019, 09:41:41 am by clatterfordslim »
But so is this Forum :)
« Reply #2 on: August 02, 2019, 10:06:17 am »
I hope this helps?
Thank you.
I know it won't be an issue once I disable it. The thing is, I wanna use it  :D
Re: Cursor Randomly Jumps When Using Synaptics Touchpad
« Reply #4 on: August 02, 2019, 01:05:52 pm »
See here
https://forum.peppermintos.com/index.php/topic,1239.0.html
or
https://forum.peppermintos.com/index.php/topic,8409.msg86680.html#msg86680
or
https://forum.peppermintos.com/index.php/topic,2067.msg20145.html#msg20145
or
https://forum.peppermintos.com/index.php/topic,2522.msg24771.html#msg24771
give us a shout if you have any questions.
Sorry about starting another thread on this. This solution works perfectly fine for me.
I set it to 0.3 second. There is no lag and I can use the touchpad right after hitting the last stroke -- without the cursor driving me insane  >:(
Thank you.   :)
Re: Cursor Randomly Jumps When Using Synaptics Touchpad (SOLVED)
« Reply #5 on: August 02, 2019, 01:18:54 pm »
You're most welcome, glad it worked for you :)
« Reply #6 on: August 02, 2019, 04:09:11 pm »
Thank you.
For me I have to disable it as it is a right pain it jumping everywhere, still glad that script helped that PCNetSpec found.  ;D
« Last Edit: August 02, 2019, 04:14:29 pm by clatterfordslim »
« Reply #7 on: August 06, 2019, 03:22:57 am »
I've noticed it still jumps on me a little from time to time, but it's not nearly as frequent or painful as it used to be.
