Author Topic: .sh files won't run  (Read 381 times)
Offline M3TWJ
  • Linux vs Windows vs Apple Linux wins
  • Peppermint version(s): 9, 10
.sh files won't run
« on: July 29, 2019, 10:38:02 pm »
so i downloaded a program that is a .sh file i folowed it command to execute it as an executable file double clicked it hit run nothing happens can you tell me what  i did wrong
Re: .sh files won't run
« Reply #1 on: July 30, 2019, 06:14:46 am »
Try running it in the terminal by typing the full path and filename. Do you see any output?
« Reply #2 on: July 30, 2019, 09:41:43 am »
It's may be that the script doesn't have permission to execute, so try right-clicking the .sh file, then selecting "Properties" then the "Permissions" tab, then put a tick in "Allow executing files as program".
If that bot is already ticked, do as murraymint suggests and try running it from within a terminal .. and post what is returned in the terminal.
It also wouldn't hurt if you could link to where you got the script.
« Last Edit: July 30, 2019, 09:45:18 am by PCNetSpec »
Offline M3TWJ
« Reply #3 on: July 30, 2019, 04:05:37 pm »
when i load it in terminal it goes off fast and i get from this link
https://www.firestormviewer.org/linux/
Offline M3TWJ
« Reply #4 on: July 30, 2019, 04:13:04 pm »
« Reply #5 on: July 30, 2019, 05:32:13 pm »
Can you please not post screenshots of requested text, text in images isn't searchable and cannot be copy/pasted.
(always better if you copy/paste the text into this forum)
Can you post the output from:
glxinfo | grep "OpenGL version"
Offline M3TWJ
« Reply #6 on: July 30, 2019, 06:06:36 pm »
oh sorry i didnt mean to i do it in terminal in the same folder right
Offline M3TWJ
« Reply #7 on: July 30, 2019, 06:09:51 pm »
from the inxi -Fz
raven@raven-IOTA2320 ~ $ inxi -Fz
System:    Host: raven-IOTA2320 Kernel: 4.18.0-25-generic x86_64 bits: 64
Machine:   Device: desktop System: iOTA product: IOTA2320 serial: N/A
           Mobo: N/A model: N/A serial: N/A
           UEFI: American Megatrends v: HW-BI-14-S133AR120-AA34J-009-A date: 11/06/2017
CPU:       Quad core Intel Pentium N4200 (-MCP-) cache: 1024 KB
           clock speeds: max: 2500 MHz 1: 704 MHz 2: 734 MHz 3: 867 MHz 4: 865 MHz
Graphics:  Card: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Graphics Controller
           Resolution: 1920x1080@57.31hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 505 (Broxton)
           version: 4.5 Mesa 18.2.8
Audio:     Card Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
           Sound: Advanced Linux Sound Architecture v: k4.18.0-25-generic
Network:   Card: Intel Wireless 3165 driver: iwlwifi
           IF: wlp1s0 state: up mac: <filter>
Drives:    HDD Total Size: NA (-)
           ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
Partition: ID-1: / size: 29G used: 7.3G (28%) fs: ext4 dev: /dev/mmcblk0p2
Sensors:   System Temperatures: cpu: 32.0C mobo: N/A
Info:      Processes: 196 Uptime: 1:03 Memory: 719.6/3778.0MB
And the glxinfo
raven@raven-IOTA2320 ~ $ glxinfo | grep "OpenGL version"
OpenGL version string: 3.0 Mesa 18.2.8
« Last Edit: July 30, 2019, 09:38:41 pm by M3TWJ »
« Reply #8 on: July 31, 2019, 02:27:04 pm »
Have you got Chrome installed for the pepperflash plugin .. as stated as a requirement in the install notes
https://wiki.firestormviewer.org/downloads#supported_operating_systems
or at least pepperflashplugin-nonfree
Is your system fully updated because I'd expect your Peppermint 10 to have mesa version 19.0.2 (not 18.2.8) ?
« Last Edit: July 31, 2019, 03:03:10 pm by PCNetSpec »
Offline M3TWJ
« Reply #9 on: July 31, 2019, 04:11:52 pm »
it was a fresh install and it all updated nd upgraded
Offline M3TWJ
« Reply #10 on: August 01, 2019, 08:35:02 pm »
so I tryed the install.sh nd that worked just it went to my home folder and installed the firestorm viewer application under internet but when i click on it nothing opens it like the .sh file for firesstorm is dening access the file is set to executable so I am still struggling on this and i am useing peppermint os 10 not 9
« Reply #11 on: August 01, 2019, 08:41:57 pm »
If I had to guess I'd say this is something to do with your graphics drivers and mesa version .. I'm currently trying to find some similar hardware to test this theory because as I said it works perfectly for me.
Offline M3TWJ
« Reply #12 on: August 01, 2019, 08:45:14 pm »
right okay just did a recheck of my glxinfo and it now on 19.02 but i not sure if i can get the drivers for my laptop as it use to run windows till it lagged out for me i keep digging myself
