Author Topic: Another converted machine  (Read 553 times)
« on: July 19, 2019, 04:19:03 pm »
Just converted another machine to Peppermint  :D
~ $ inxi -Fx
System:    Host: TOSHIBA-NB250 Kernel: 4.18.0-25-generic i686 bits: 32 gcc: 7.4.0 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: laptop System: TOSHIBA product: TOSHIBA NB250 v: PLL2PE-009009EP serial: N/A
           Mobo: TOSHIBA model: PAV10 DDR2 v: 1.00 serial: N/A BIOS: TOSHIBA v: V1.60 date: 07/30/2010
Battery    BAT1: charge: 46.1 Wh 100.0% condition: 46.1/47.5 Wh (97%) model: TOSHIBA PA3835U-1BRS status: N/A
CPU:       Single core Intel Atom N455 (-MT-) arch: Bonnell rev.10 cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3325
           clock speeds: max: 1667 MHz 1: 1216 MHz 2: 1233 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.20.4 ) drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1024x600@60.00hz
           OpenGL: renderer: Mesa DRI Intel Pineview M x86/MMX/SSE2 version: 1.4 Mesa 19.0.2 Direct Render: Yes
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.18.0-25-generic
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 07:00.0
           IF: wlp7s0 state: up mac: 00:26:4d:f5:22:ad
           Card-2: Realtek RTL810xE PCI Express Fast Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 09:00.0
           IF: enp9s0 state: down mac: 1c:75:08:6f:e9:7e
Drives:    HDD Total Size: 250.1GB (2.9% used)
           ID-1: /dev/sda model: TOSHIBA_MK2565GS size: 250.1GB
Partition: ID-1: / size: 229G used: 6.8G (4%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 51.0C mobo: N/A
Info:      Processes: 152 Uptime: 7 min Memory: 214.8/923.0MB Init: systemd runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.201) inxi: 2.3.56
Offline VinDSL
Re: Another converted machine
« Reply #1 on: July 19, 2019, 04:29:04 pm »
Noice!
P10 and Linux 4.18.x FTW   :D
« Reply #2 on: July 19, 2019, 08:29:12 pm »
Good to see Peppermint still doing the netbook thing .. where I first started :)
Though I bet 1GB RAM is a little painful on 18.04 based builds (?), IIRC I kinda gave up on <2GB systems and Ubuntu after 14.04 .. it'll work for sure, but sadly it's not the best experience any more :(
Offline VinDSL
« Reply #3 on: July 19, 2019, 09:34:22 pm »
[...] it'll work for sure, but sadly it's not the best experience any more :(
I have a lot of 'painfully slow' machines, but I continue to upgrade and use them anyway.
At the other end of the scale, I have some 'blindingly fast' machines. I upgrade them, but rarely turn them on.
I'm at a loss to explain this, other than to say, it's akin to owning a classic car, or '42 Indian Chief motorcycle.
The only thing that sucks on my Eee PC is when I open a modern browser window. Then, it slows to a crawl.
I've been looking around for a suitable substitute, but yet to find one. In the meantime, it's what I make of it.
P10 & Linux 4.18.x is a wicked combination. It's not painful at all, until one starts aimlessly surfing the web.
« Reply #4 on: July 20, 2019, 03:18:37 am »
I'll, at least, warn the owner about the limitations of this thing.
1GB and HDD is not a good duo  :D
Offline VinDSL
« Reply #5 on: July 20, 2019, 11:23:27 am »
Tell 'em to dual-boot it with winders XP. That's what I do.
Just don't hook it up to the web...  :D
« Reply #6 on: July 20, 2019, 11:26:03 am »
 :D oh man...  :D
Offline VinDSL
« Reply #7 on: July 20, 2019, 11:43:48 am »
Hey, that's what it was designed to use.
My Eee PC even has a 'speed boot' haxor baked into the BIOS, and a hidden partition on the drive to accommodate it.
XP is fun to mess with - like playing with fire, behind the house, when I was a kid.
It's okay until you start the field on fire, you know?   ;D
Seriously, as I've said before, the only reason I keep XP around is so I can update/maintain my print server.
Netgear, in their infinite wisdom, made their proprietary print server utility XP specific, and there's no workaround AFAIK, but I digress.
« Reply #8 on: July 20, 2019, 11:51:51 am »
I think XP is more akin to messing with nitroglycerine than a zippo at this point :)
I'd feel MUCH safer bunging say Ubuntu 10.10 on it .. which by comparison would be akin to safety matches inside a fire retardant box :))
« Last Edit: July 20, 2019, 11:56:46 am by PCNetSpec »
Offline VinDSL
« Reply #9 on: July 20, 2019, 12:21:06 pm »
Bwahahahahahahaha :))
« Reply #10 on: July 20, 2019, 03:54:29 pm »
Now, that was nice. I'd say, more like nitroglycerine in a shaker  :D
« Last Edit: July 20, 2019, 03:57:44 pm by pin »
