Author Topic: Xfce-Panel theming problem (SOLVED)  (Read 1011 times)
Offline Burkhard
  • Peppermint version(s): Peppermint10
« on: July 18, 2019, 05:27:10 am »
Hello, I Just switched the dark Xfce-Panel to a lighter theme, but some buttons (Whisker Menue Button, Volume and Keyboard Button) remain dark. How can I Switch the colour of these buttons also, so that eyerything looks equal?
« Last Edit: July 21, 2019, 09:52:48 am by Burkhard »
Re: Xfce-Panel theming problem
« Reply #1 on: July 18, 2019, 06:13:30 am »
Switch from the Pepirus-Dark Icon theme, to the Pepirus-Light one (or some other icon theme designed to work with a light background).
In:-
Menu > Settings > Customise Look and Feel > Icon Theme (tab)
You may need to log off/on before all icons change .. or at least restart the panel with:
xfce4-panel -r
You may also need to choose a light coloured/matching Gtk theme.
(in fact his is probably the issue you're having)
« Last Edit: July 18, 2019, 06:29:52 am by PCNetSpec »
Offline Burkhard
« Reply #2 on: July 19, 2019, 05:32:35 am »
No, Xfce-Panel restart doesn't solve the problem, I made a Screenshot but I don't know how to add it here. Ist there a theme script anywhere where I can change the desired button color? As I said, theme is installed in the way you explained, thanks for your quick answer.
« Reply #3 on: July 19, 2019, 01:57:23 pm »
Offline Burkhard
« Reply #4 on: July 20, 2019, 12:36:31 pm »
So, okay, here comes the Screenshot. As you See in the left Panelside one Button/area/Icon remains dark (Whisker-menue), also on the right side beneath the time. Theme is Telinkrin.
« Reply #5 on: July 20, 2019, 01:46:27 pm »
The best way to achieve what you want would be to create a panel-backgound image in the colour(s) you want .. you can use the one at:-
/usr/share/peppermint/images/peppermix-panel-background.png
as a template.
Save it somewhere.
Then point the panel preferences at it .. as in:-
Offline Burkhard
Re: Xfce-Panel theming problem (SOLVED)
« Reply #6 on: July 21, 2019, 09:57:49 am »
Taking the peppermint.png leads to a complete dark panel, but you are on the right way, switching in the panel settings to the desired colour solved the problem. Hopefully in the way with peppermint 10.
« Reply #7 on: July 21, 2019, 11:54:44 am »
Yeah I meant for you to CREATE a light background image file using peppermix-panel-background.png as a template .. not to use it 'as is'.
« Reply #8 on: July 21, 2019, 01:41:22 pm »
I've been following this thread, but keeping my 'mouth' shut - but, you finally said it :))
To the OP: I've made loads of custom desktops. Here's a small sampling:
https://www.bing.com/images/search?q=VinDSL&FORM=HDRSC2
All I can tell you is, GiMP is your friend.
