Author Topic: Broken USB Port 3.0  (Read 1013 times)
Broken USB Port 3.0
« on: July 02, 2019, 07:54:34 am »
Hello Peppermint.
Yesterday the 3.0 port on my 5 year old Toshiba Satellite died.  Since I do use every port on this laptop computer (It looks much like this), I'm now gathering ideas as to how address this issue.
Any suggestions as for how to add another port on this aging desktop replacement computer?  I don't want to bring it to a local computer repair shop if I don't absolutely have to.
Thank you,
perknh
Re: Broken USB Port 3.0
« Reply #1 on: July 02, 2019, 10:02:00 am »
Which model of Satellite ?
Has it got a PCMCIA Express slot ?
If not, I'm sure the Chinese will sell you a USB 2.0 --> USB 3.0 adapter :))
« Last Edit: July 02, 2019, 10:09:13 am by PCNetSpec »
« Reply #2 on: July 02, 2019, 08:35:38 pm »
-- PCNetSpec
Thanks, PCNetSpec.  Heck if I know.  But if a picture is worth a thousand words, here is what it looks like.  But you got to click onto the picture 6 times to see what I'm looking at here.  Sorry. :-[
https://www.ebay.com/itm/Toshiba-Satellite-C70D-A-17-3-Laptop-i3-3120M-2-50GHz-750GB-HDD-8GB-Ram-DVD-RW/153525516897?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908103841%26meid%3Da4c75560fc9143d681c6d05eb5bbd8cd%26pid%3D100227%26rk%3D1%26rkt%3D10%26sd%3D153525516897%26itm%3D153525516897&_trksid=p2054502.c100227.m3827
Satellite C70-A
And, just in case, here's its inxi -Fz too!
perknh@peppermint ~ $ inxi -Fz
System:    Host: peppermint Kernel: 4.18.0-25-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: laptop System: TOSHIBA product: Satellite C70-A v: PSCE2U-03E00S serial: N/A
           Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1 v: Type2 - Board Version serial: N/A
           UEFI [Legacy]: Insyde v: 1.30 date: 04/18/2014
Battery    hidpp__1: charge: N/A condition: NA/NA Wh
CPU:       Dual core Intel Pentium 2020M (-MCP-) cache: 2048 KB
           clock speeds: max: 2400 MHz 1: 1197 MHz 2: 1197 MHz
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller
           Resolution: 1600x900@60.01hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
           version: 4.2 Mesa 18.2.8
Audio:     Card Intel 7 Series/C216 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.18.0-25-generic
Network:   Card-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
           IF: wlp2s0 state: down mac: <filter>
           Card-2: Qualcomm Atheros AR8162 Fast Ethernet driver: alx
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 360.1GB (5.6% used)
           ID-1: /dev/sda model: PNY_CS1311_240GB size: 240.1GB
           ID-2: USB /dev/sdb model: 2105 size: 120.0GB
Partition: ID-1: / size: 110G used: 19G (18%) fs: ext4 dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 48.0C mobo: N/A
Info:      Processes: 169 Uptime: 6 min Memory: 676.6/5854.9MB
-- PCNetSpec
Good one!!  I'll only believe it if and when I see a blue piece of plastic inside!  ;D
Off topic:
Installed Peppermint 10 onto an HP Stream tonight.  Firefox's default search engine was Google.  I didn't see Peppermint DDG anywhere.  I added it though through perknhs-personal-startpage.  Thought you should know.  Might be a one-off install, who knows?  Chromium, incidentally, has no such issue.
« Last Edit: July 03, 2019, 06:14:37 am by perknh »
« Reply #3 on: July 02, 2019, 08:38:16 pm »
Now that you mention it, I did an install today with the same result.
« Reply #4 on: July 03, 2019, 09:12:28 am »
Quote from: perknh
Okay I'm gonna need to look into that then .. thanks for the heads up.
Sorry perknh, that doesn't have an expresscard slot, so I can't think of any way of easily adding USB 3
« Last Edit: July 03, 2019, 09:17:12 am by PCNetSpec »
« Reply #5 on: July 04, 2019, 05:10:49 am »
That's okay, I don't need a USB 3.  All I need is another USB port. Is there something I can buy to insert into the one working USB 2 port I have on that side of the computer that would give me two working USB 2 ports -- something like what you can do from a wall jack in your house?  See I normally use a mouse and a fan on that side of the computer, and now I have no working fan.  I don't care if something hangs out of the side of the computer because this computer never travels anywhere anyhow.
« Reply #6 on: July 04, 2019, 05:37:00 am »
Yes, it's called a USB hub. You usually get at least four ports by plugging it into one.
« Reply #7 on: July 04, 2019, 06:23:32 am »
That's what I need then.  Thanks, murraymint. :)
« Reply #8 on: July 04, 2019, 03:41:06 pm »
We're talking about something like this, aren't we, murraymint?
I think that's what I'm looking for. ;)
« Reply #9 on: July 04, 2019, 05:53:12 pm »
Yes that is an unpowered USB hub, but they don't have to look that horrible pernkh.
https://www.ebay.com/itm/7-Port-Aluminum-USB-3-0-Hub-5V-2A-Power-Adapter-for-PC-Laptop-Notebook-Desktop/132225990464
there are thousands to choose from. (just search amazon/ebay for "usb 3.0 hub" or similar).
But depending on what you are planning on connecting to it, you may or may not  want a powered hub. (?)
Question .. is the USB port that's left USB 2 or USB 3 ?
« Last Edit: July 04, 2019, 06:10:33 pm by PCNetSpec »
Offline VinDSL
« Reply #10 on: July 04, 2019, 06:14:29 pm »
Swank: https://www.walmart.com/ip/Insten-7-Port-USB-Hub-with-ON-OFF-Switch-Adapter-LED-Light/28881656
How do they make a profit, selling these things for 5 bucks???
« Reply #11 on: July 04, 2019, 08:03:05 pm »
Ahh, but mine looks like it's made for Apple users, so obviously it's worth more right ? :P
(but you do also get the 2A power brick in case you wanna add anything that draws more power than the USB port can supply)
« Last Edit: July 04, 2019, 08:08:34 pm by PCNetSpec »
« Reply #12 on: July 04, 2019, 08:32:08 pm »
It's a USB 2.
« Reply #13 on: July 04, 2019, 08:38:35 pm »
I've got one of those. It's quite handy supposing you never need it.
« Reply #14 on: July 04, 2019, 09:11:24 pm »
4 stars, 5 bucks -- that's amazing! :o
