Author Topic: Bluetooth speaker not found (SOLVED)  (Read 1796 times)
Re: Bluetooth speaker not found
« Reply #15 on: June 28, 2019, 11:18:24 am »
The problem must be about putting the devices in pairing mode then .. bluetooth is obviously working.
Offline mefibo
« Reply #16 on: June 29, 2019, 04:32:05 am »
So it seems to be a compatibility issue, I can live with that.
« Last Edit: June 29, 2019, 04:37:01 am by mefibo »
« Reply #17 on: June 29, 2019, 07:29:12 am »
I doubt if it's a compatibility issue, it's just that you need to figure out how to put the device into pairing mode .. then whilst it's in pairing mode (it'll probably only stay in pairing mode for 2 mins) search for it from within Peppermint.
Offline mefibo
« Reply #18 on: June 29, 2019, 11:06:20 am »
I have really tried every combination of the keys on my JBL Flip 2, with no luck. But more important; both speakers connect without any problem with my phone, my windows laptop and even on my HP Stream with Peppermint 10 installed! Is there a way to just update the bluetooth manager because of my RAM problems with 10 as posted in ¨RAM fills up¨?
« Last Edit: June 29, 2019, 01:11:26 pm by mefibo »
« Reply #19 on: June 29, 2019, 03:58:20 pm »
It might be a kernel issue, because other than having a later kernel all the bluetooth stuff is the same between PM9 and PM10 .. but if we update your kernel, the memory problem might return.
Offline mefibo
« Reply #20 on: June 29, 2019, 04:16:55 pm »
Please, I want to try... I am not afraid of a (re-) install. Have installed Peppermint 9 and 10, Lubuntu, Fedora, Manjaro, Mint etc.
« Reply #21 on: June 29, 2019, 05:33:51 pm »
Run:
sudo apt-get install --install-recommends linux-generic-hwe-18.04 xserver-xorg-hwe-18.04  when that command finishes .. REBOOT.
Then post the output from:
uname -aand hopefully it'll say you're on the 4.18 kernel.
Now if bluetooth works, but the memory issue returns .. maybe we can try moving you to the hwe-edge track (and hence the 5.0 series kernel) and see if that helps.
Offline mefibo
« Reply #22 on: June 29, 2019, 07:22:30 pm »
Now I am at the 4.18 kernel, but indeed the RAM eating has reoccurred, though Bluetooth works. Sound coming out my JBL Flip 2. I am awaiting your further instructions.
mefibo@mefibo-HP-Stream-Notebook-PC-11 ~ $ uname -a
Linux mefibo-HP-Stream-Notebook-PC-11 4.18.0-25-generic #26~18.04.1-Ubuntu SMP Thu Jun 27 07:28:31 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
« Last Edit: June 29, 2019, 07:57:33 pm by mefibo »
« Reply #23 on: June 30, 2019, 07:42:47 pm »
Okay let's see what happens if we move you to the 5.0 kernel via the 18.04-hwe-edge track.
Open a terminal and run:
sudo apt-get install --install-recommends linux-generic-hwe-18.04-edgewhen that command finishes REBOOT   <-- IMPORTANT
Once rebooted, post the output from
uname -aand test if your memory is still climbing ?
Offline mefibo
« Reply #24 on: July 01, 2019, 04:04:53 am »
Here is a very, very happy user:
Linux mefibo-HP-Stream-Notebook-PC-11 5.0.0-20-generic #21~18.04.1-Ubuntu SMP Thu Jun 27 04:04:37 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
The speaker works fine and RAM usage is stable!
Thank you very much for your persistent help. Now I can stay with the -by far - best linux distro I came across.
Should I refer to this topic in my topic (already marked as SOLVED cause I changed from 10 to 9) RAM fills up? After your answer, I will also mark this one as SOLVED.
« Reply #25 on: July 01, 2019, 04:44:41 am »
Great news and you're most welcome :)
You now have to decide whether to reinstall PM10 then move to the hwe-18.04-edge track with just
sudo apt-get install --install-recommends linux-generic-hwe-18.04-edgeor to do a manual upgrade of PM9 --> PM10 following these instructions
https://forum.peppermintos.com/index.php/topic,8442.msg86655.html#msg86655
or just to stay as is :)
BTW, I added this info to your other topic for you:
https://forum.peppermintos.com/index.php/topic,8578.msg88212.html#msg88212
Offline mefibo
« Reply #26 on: July 01, 2019, 05:25:39 am »
Thanks.
I see no reason to reinstall 10 right now, so I am going to stay with 9.
« Last Edit: July 01, 2019, 06:18:36 am by mefibo »
Re: Bluetooth speaker not found (SOLVED)
« Reply #27 on: July 02, 2019, 05:56:35 pm »
Following PCNetSpec's instructions, I no longer have to use the bluetooth dongle for bluetooth any longer in my Samsung laptop.  :)
« Reply #28 on: July 03, 2019, 05:42:22 am »
Nice :)
As it's on the rolling HWE, the 5 series kernel will be coming to Peppermint 10 for everyone in a couple of months.
« Last Edit: July 03, 2019, 05:44:05 am by PCNetSpec »
