Author Topic: Wifi not working Peppermint 10  (Read 1280 times)
Offline anvvsharma
« on: June 23, 2019, 03:47:20 am »
Hi Team,
I am newbee for peppermint installed it recently.  WIFI is not working in my newly installed peppermint 10. i could not read the wifi connection around. below are the details...
$$>> inxi -Fnxxxz ; nmcli radio wifi on ; rfkill list all
System:    Host: ayyalasomayajula-SandyBridge-Platform Kernel: 4.18.0-22-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: N/A info: xfce4-panel dm: lightdm Distro: Peppermint Ten
Machine:   Device: laptop System: Intel product: SandyBridge Platform serial: N/A
           Mobo: Intel model: N/A v: E98683-352 serial: N/A
           UEFI: Intel v: S1200BT.86B.02.00.0035.030220120927 date: 03/02/2012
CPU:       Quad core Intel Xeon E3-1230 V2 (-MT-MCP-)
           arch: Ivy Bridge rev.9 cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 26340
           clock speeds: min/max: 1600/3700 MHz 1: 1596 MHz 2: 1596 MHz 3: 1596 MHz
           4: 1597 MHz 5: 1596 MHz 6: 1596 MHz 7: 1596 MHz 8: 1596 MHz
Graphics:  Card: NVIDIA GK208B [GeForce GT 710] bus-ID: 01:00.0 chip-ID: 10de:128b
           drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau)
           Resolution: 1440x900@59.89hz
           OpenGL: renderer: GeForce GT 710/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.116 Direct Render: Yes
Audio:     Card-1 Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
           driver: snd_ca0106 port: 2000 bus-ID: 04:00.0 chip-ID: 1102:0007
           Card-2 NVIDIA GK208 HDMI/DP Audio Controller
           driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0e0f
           Sound: Advanced Linux Sound Architecture v: k4.18.0-22-generic
Network:   Card-1: Intel 82579LM Gigabit Network Connection (Lewisville)
           driver: e1000e v: 3.4.2.4-NAPI port: 6040
           bus-ID: 00:19.0 chip-ID: 8086:1502
           Card-2: Intel 82574L Gigabit Network Connection
           driver: e1000e v: 3.4.2.4-NAPI port: 3000
           bus-ID: 03:00.0 chip-ID: 8086:10d3
           IF: rename3 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 2516.2GB (1.6% used)
           ID-1: /dev/sda model: WDC_WD20EZRX size: 2000.4GB serial: <filter>
           ID-2: /dev/sdb model: ST3500418AS size: 500.1GB serial: <filter>
           ID-3: USB /dev/sdc model: Cruzer_Blade size: 15.7GB serial: <filter>
Partition: ID-1: / size: 1.5T used: 2.9G (1%) fs: ext4 dev: /dev/sda5
           ID-2: /usr size: 183G used: 5.3G (4%) fs: ext4 dev: /dev/sda4
           ID-3: /boot size: 945M used: 169M (20%) fs: ext4 dev: /dev/sda1
           ID-4: /home size: 183G used: 796M (1%) fs: ext4 dev: /dev/sda3
           ID-5: swap-1 size: 32.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
RAID:      System: supported: N/A
           No RAID devices: /proc/mdstat, md_mod kernel module present
           Unused Devices: none
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 0.0:51C
Info:      Processes: 268 Uptime: 4 min Memory: 1538.0/15754.2MB
           Init: systemd v: 237 runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.191 running in sakura) inxi: 2.3.56
[/i]
Wireless connection details :
$ > iwconfig
eno1      no wireless extensions.
rename3   no wireless extensions.
docker0   no wireless extensions.
Network Details :
$> lspci | grep -i network
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 05)
03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
thanks in advance
Sharma
Re: Wifi not working Peppermint 10
« Reply #1 on: June 23, 2019, 09:51:24 am »
Can you post the output from
lspci -vnn | grep -i netand
rfkill listand
iwconfigand
sudo iwlist scan
Offline anvvsharma
« Reply #2 on: June 23, 2019, 10:27:15 am »
find the details below
~ $ lspci -vnn | grep -i net
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) [8086:1502] (rev 05)
03:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
 ~ $ rfkill list
<empty>
~ $ sudo iwlist scan
eno1      Interface doesn't support scanning.
docker0   Interface doesn't support scanning.
rename3   Interface doesn't support scanning.
« Reply #3 on: June 23, 2019, 11:00:49 am »
iwconfigPlease.
« Reply #4 on: June 23, 2019, 02:25:42 pm »
Well that's not showing a discovered wireless adapter at all :-\
Is it an internal adapter or a USB wireless card ?
What's the output from:
lsusb
Are you sure there's a wireless adapter at all ? .. if so, have you somehow disabled it via the BIOS or a hardware switch ?
I'm seeing TWO ethernet adapters, but NO wireless adapter :-\
« Last Edit: June 23, 2019, 02:28:14 pm by PCNetSpec »
Offline anvvsharma
« Reply #5 on: June 24, 2019, 08:54:32 am »
Yes i dont see wireless adaptpers ; how to install them
please find below information
~ $ iwconfig
~ $ lsusb
Bus 002 Device 004: ID 1bcf:0007 Sunplus Innovation Technology Inc. Optical Mouse
Bus 002 Device 003: ID 1a2c:0c21 China Resource Semico Co., Ltd
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
« Reply #6 on: June 24, 2019, 02:46:25 pm »
Hmm!
It doesn't look like you have a wifi card...
Have you EVER used wifi on this machine? Maybe the card is broken/disconnected?
You could always get an usb-wifi dongle.
« Reply #7 on: June 24, 2019, 02:53:05 pm »
I mean I'm not seeing any detected wireless hardware at all :-\
Offline anvvsharma
« Reply #8 on: June 27, 2019, 06:58:56 am »
yes i never used WIFI in this machine. Does this need a hardware wifi to detect
« Reply #9 on: June 27, 2019, 08:04:29 am »
Yeah, it looks like it has NO wireless hardware, so you're going to need to add the hardware.
