Author Topic: Asus Eee 1005P battery problem  (Read 445 times)
Offline Sgt. Pepper
« on: June 22, 2019, 01:44:25 am »
Hello,
I was running Ubuntu Mate 18.04 previously, but got into some issues and decided to try Peppermint.
Peppermint works great and is noticeable faster. There is a problem with the battery though, it is always stuck at 100% regardless of charging/discharging. It was working well in Mate before.
Acpi says: "Battery 0, Charging, 100%,    until charged".
Ideas anyone?
Cheers,
Sgt. Pepper
« Last Edit: June 22, 2019, 01:52:26 am by Sgt. Pepper »
Re: Asus Eee 1005P battery problem
« Reply #1 on: June 22, 2019, 04:41:36 pm »
Try replacing xfce4-power-manager with mate-power-manager...
Run:
sudo apt-get install mate-power-manager
sudo apt-get remove xfce4-power-manager xfce4-power-manager-data xfce4-power-manager-plugins
Now go to:-
Menu > Settings > Default Applications for LXSession > Core applications (tab)
Change:-
Power Manager: xfce4-power-manager
to
Power Manager: mate-power-manager
exit the LXSession configuration app
Reboot. <-- IMPORTANT
The power manager in the system tray should now be the MATE Power Manager.
Offline Sgt. Pepper
« Reply #2 on: June 24, 2019, 01:30:38 am »
Hello again,
I followed the provided recipe, result is I'm without power icon in sys tray now. Nothing happening when I call up the Power Manager in Peppermint Settings Panel/Hardware. Acpi still says the same as before. Hardware problem?
Thanks for your help.
« Reply #3 on: June 24, 2019, 12:04:06 pm »
What's the output from:
ps aux | grep [p]ower-manager
