Author Topic: No USB2 support Virtualbox 6  (Read 354 times)
« on: June 17, 2019, 01:47:10 pm »
Hi guys
I've got a Windows 7 guest running in Virtualbox 6 on a friends laptop and I can't get it recognise any USB drives,
I have Guest Additions and the extension pack installed I have the user added to vboxuser group & USB 2 enabled in VB settings and no USB drive is being recognised by the guest.
Virtualbox 6 has support for USB 1, 2 & 3 and I've tried them all, that said USB 3 will not install because it can't find the driver but USB 2 would be fine, I've searched endlessly for a solution for this and I've eliminated everything I can find but it just won't work
Has anyone any idea what the problem might be ?
Many thanks
