Author Topic: How to change fonts in Nemo?  (Read 832 times)
Offline NoPride
« on: June 14, 2019, 11:45:48 am »
As the title says how do I change fonts in Nemo?
I was able to change fonts everywhere else except there.
Thanks
Re: How to change fonts in Nemo?
« Reply #1 on: June 14, 2019, 02:57:48 pm »
Menu > Settings > Customize Look and Feel
On the Widget tab, which is up by default, go to the bottom right and change the font setting there. That changes the font in Nemo.
« Reply #2 on: June 14, 2019, 03:05:06 pm »
Or for the desktop
Menu > System > dconf Editor
org > nemo > desktop > font
But be careful in there.
Offline NoPride
« Reply #3 on: June 14, 2019, 03:49:17 pm »
Thanks for replying, but it did not solve the problem.
as you can see here:
https://i.imgur.com/rXgk2A2.png
I changed it to Noto Sans Bold 8 but it's not changing in Nemo
See here: https://i.imgur.com/cyTV0lp.png
The font are not bold. Everywhere else is fine except there.
« Reply #4 on: June 14, 2019, 04:21:59 pm »
In a nemo file manager window the font is set in
as scifidude79 suggests.
Offline NoPride
« Reply #5 on: June 14, 2019, 04:31:29 pm »
It's not using bold font everywhere tho. Just title and stuff.
« Reply #6 on: June 14, 2019, 05:00:42 pm »
You're right. The font itself in Nemo will change, but it won't go bold. It's possible that's because Nemo is from the MATE desktop and LXAppearance is from LXDE. Though, it's also possible Nemo just isn't designed to use bold fonts.
