Author Topic: Random forced shutdowns  (Read 408 times)
Offline humanoidtypo
« on: June 11, 2019, 10:08:46 am »
Hello,
I recently installed Peppermint 10 on my old 32-bit laptop (HP Pavilion dv2000). Everything works great but the Peppermint keeps shutting down the laptop frequently. This usually happens during high-intensity tasks like installing software, updates or extracting a compressed file. I thought it was the CPU over heating or something but I installed Psensor and temperatures are usually around 60-70 C.
I previously had Windows 10 installed and it never did anything like this.
Any idea on fixes?
Re: Random forced shutdowns
« Reply #1 on: June 11, 2019, 05:45:43 pm »
Run:
sudo sensors-detect
and answer Y or yes to all the prompts.
when that's finished run:
/etc/init.d/kmod start
did that help ?
Can you post the output from:
« Reply #2 on: June 12, 2019, 12:04:05 am »
Thanks for the help! I ran those commands. Here's the output:
System:    Host: HP-Pavilion-dv2000-GA481UA-ABA Kernel: 4.18.0-21-generic i686
           bits: 32
Machine:   Device: laptop System: Hewlett-Packard product: HP Pavilion dv2000 (GA481UA#ABA) v: F.34 serial: N/A
           Mobo: Wistron model: 30B2 v: 61.61 serial: N/A
           BIOS: Hewlett-Packard v: F.34 date: 06/02/2007
CPU:       Dual core Intel Core Duo T2450 (-MCP-) cache: 2048 KB
           clock speeds: max: 2000 MHz 1: 809 MHz 2: 820 MHz
Graphics:  Card: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics Controller
           drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1280x800@59.91hz, 1280x1024@60.02hz
           OpenGL: renderer: Mesa DRI Intel 945GM x86/MMX/SSE2
           version: 1.4 Mesa 18.2.8
Audio:     Card-1 Intel NM10/ICH7 Family High Def. Audio Controller
           Card-2 Logitech Webcam C930e driver: USB Audio
           Sound: Advanced Linux Sound Architecture v: k4.18.0-21-generic
Network:   Card-1: Intel PRO/Wireless 3945ABG [Golan] Network Connection
           driver: iwl3945
           IF: wlp5s0 state: down mac: <filter>
           Card-2: Intel PRO/100 VE Network Connection driver: e100
           IF: enp8s8 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 320.1GB (4.0% used)
           ID-1: /dev/sda model: ST9320325AS size: 320.1GB
Partition: ID-1: / size: 293G used: 12G (5%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 60.0C mobo: 43.0C
Info:      Processes: 179 Uptime: 39 min Memory: 834.9/2445.1MB
Update: I tried some tasks to bring up the CPU and Peppermint still auto shuts down. One thing that always seems to trigger shutdown is when I install an app from the software centre while browsing the web. CPU tempurature goes up to around 85 C and the laptop auto shuts down when the temp reaches around 90 C.
« Last Edit: June 12, 2019, 12:25:11 am by humanoidtypo »
