Author Topic: Virtualbox woes (SOLVED)  (Read 1142 times)
Re: Virtualbox woes
« Reply #15 on: June 12, 2019, 01:10:00 am »
That sorted it, after disabling secure boot jt started to run the installation fine, I did run into another error but following alynurs advice of removing ~/Virtualbox VMs and restarting the installation again sorted it, so all's well that ends well
Thanks guys
« Last Edit: June 12, 2019, 09:17:03 am by emegra »
Re: Virtualbox woes (SOLVED)
« Reply #16 on: June 12, 2019, 07:00:45 am »
Great news :)
