Author Topic: Nextcloud Password Prompt [SOLVED]  (Read 579 times)
Offline stroudmw
  • Peppermint version(s): 8 32 bit
« on: June 10, 2019, 05:29:55 am »
I'm running Peppermint 10 64bit. I've just installed Nextcloud via the ppa (not the flatpack). Whenever I reboot, I get asked for my password (the Keyring password, not the user login password - I've already entered that). How do I stop this? It's really annoying having to enter the password twice.
« Last Edit: June 13, 2019, 12:05:48 am by stroudmw »
Offline stroudmw
Re: Nextcloud Password Prompt
« Reply #1 on: June 12, 2019, 07:12:52 am »
Anyone? Please? It's wanting a keyring password. I've already entered a password.
« Reply #2 on: June 12, 2019, 01:37:52 pm »
NextCloud not being part of Peppermint may mean it's best triaged via https://portal.nextcloud.com/category/authentication/ but perhaps other team members here may have experience with it that I do not have
« Reply #3 on: June 12, 2019, 02:00:35 pm »
Try this...
Open a terminal and run
mv -v ~/.local/share/keyrings ~/.local/share/keyrings-originalthen
mkdir ~/.local/share/keyringsthen
sudo apt-get install libpam-gnome-keyringNow REBOOT<--it MUST be a REBOOT, it's not enough to log off/on
If after a reboot you're asked for a Keyring Password, LEAVE IT BLANK .. it'll probably bitch about leaving it blank but accept and continue anyway.
Reboot again to check you're no longer asked.
Offline stroudmw
« Reply #4 on: June 13, 2019, 12:04:13 am »
Perfect! Thanks so much!
Re: Nextcloud Password Prompt [SOLVED]
« Reply #5 on: June 13, 2019, 04:41:25 am »
Great stuff, thanks for marking the topic (SOLVED) :)
