Author Topic: Pepp10 boots with a HP Laptop not with a desktop running Win7.  (Read 1493 times)
Offline GEMS
Greetings,
We are making progress but presently stumped. Pepp10 is on a external SSD and boots with my HP laptop. When I connect it to my desktop with Win7 it will not boot.
It is recognized in Bios and I designate it as the boot device. I get the initial black and white screen where you can select to progress or wait for the timeout and it will continue by itself. Thereafter the blinking cursor blinks about twice and the screen turns black and white text fills about one and a half screens. I cant screen print because I have to manually shut down the computer to escape and disconnect the external drive so it will then boot into Win7.
Any ideas? Thanks in advance.
GEMS.
Re: Pepp10 boots with a HP Laptop not with a desktop running Win7.
« Reply #1 on: June 06, 2019, 03:17:56 pm »
Does the laptop have proprietary graphics driver, such as 'nvidia' loaded ?
(but the desktop doesn't have an nvidia card)
For example, if you installed Peppermint on the laptop and installed the proprietary nvidia drivers, it will now not boot on a system without an nvidia card .. that's the downside of proprietary drivers.
« Last Edit: June 06, 2019, 03:19:46 pm by PCNetSpec »
Offline GEMS
« Reply #2 on: June 06, 2019, 10:42:06 pm »
PCNetSpec,
I thought of that. I purposefully used the stock Pepp10 drivers for the initial boot-up..
GEMS.
« Reply #3 on: June 07, 2019, 09:35:27 am »
Okay there could be other problems such as UEFI vs BIOS and possibly Secureboot.
Does a LiveUSB of Peppermint boot on the desktop ?
If so, can you post the output from:
(run in a Live environment on the desktop)
and again
(run from the external drive on your laptop)
« Last Edit: June 07, 2019, 09:37:07 am by PCNetSpec »
Offline donnielbell
« Reply #4 on: August 09, 2019, 05:35:26 pm »
32 bit or 64 not differences between those two systems? Does your system and Peppermintos have same 32 bit or 64 setup?
Sent from my LG-M150 using Tapatalk
« Reply #5 on: August 10, 2019, 02:47:44 pm »
The 32bit and 64bit versions are the same (from a users perspective), if that's what you mean ?
