Author Topic: Is there a Hex Editor in the software repositoy ? (SOLVED)  (Read 321 times)
Offline davexnet
  • Peppermint version(s): 7 64-bit
« on: June 02, 2019, 09:09:57 am »
Hi All -
I'm used to HxD in Windows, but any suggestion appreciated.
I was not able to find anything using "software manager"
Thanks
« Last Edit: June 02, 2019, 04:55:51 pm by PCNetSpec »
Re: Is there a Hex Editor in the software repositoy ?
« Reply #1 on: June 02, 2019, 11:48:17 am »
'wxhexeditor' should do the trick...  :)
Offline davexnet
« Reply #2 on: June 02, 2019, 02:52:26 pm »
Thank you very much, this seems like it will do fine
