Author Topic: Whilst typing on Lenovo Yoga Or Dell Elitebook laptops (SOLVED)  (Read 652 times)
Offline clatterfordslim
Strange things occur, the page will scroll to the bottom whilst typing, or words would end up filling in at the end of other words.  ??? It mostly happens on this website, as I'm typing this, the page went down to the bottom, cursor went back to the beginning of the document. What is causing it? I have no idea, has anyone else had this happen to them?  Confused I be  :-\
« Last Edit: June 01, 2019, 02:01:45 pm by clatterfordslim »
But so is this Forum :)
Offline josephd
  • Peppermint OS Website Admin
    • LinuxBookPro
Re: Whilst typing on Lenovo Yoga Or Dell Elitebook laptops
« Reply #1 on: May 31, 2019, 11:12:10 pm »
Any possibility you're using an ad-blocker, privacy badger or browser add on such as Grammerly? Those could be conflicting. Maybe try deactivating them and see if the problem still occurs.
« Reply #2 on: June 01, 2019, 12:06:16 am »
The only Adblocker I use is one for YouTube. I will give it a go tonight, as I use them on my night shift. It does make sense, but then here at home on my main Desktop PC it does not do it. A puzzling puzzle.  ;D
Online murraymint
« Reply #3 on: June 01, 2019, 04:40:11 am »
Try setting a delay on your touchpad so it doesn't activate while you're typing.
https://forum.peppermintos.com/index.php/topic,1239.0.html
Re: Whilst typing on Lenovo Yoga Or Dell Elitebook laptops {Solved}
« Reply #4 on: June 01, 2019, 01:59:52 pm »
Yes indeedly do I think we got it, as it has not bugged out on me as of yet, but I think the problem was also I was using my desktop mouse, am using my touchpad and after putting in those commands and logging out, it has fixed it. So marking this as solved. Just need to do the same on my Dell Elitebook. Many thanks.  ;D
