Author Topic: sudo modprobe ndiswrapper at startup (solved)  (Read 1931 times)
Offline 10i
  • Peppermint Enthusiast
    • My Peppermint Blog
« on: August 16, 2014, 03:30:27 am »
Hi guys,
Thanks to PCNetSpec my wifi card now works.
However, I need to use the above command every time I boot up, but I would like it to do it automatically. I have Googled, but am finding results for Slackware and every other kind of Linux.
Would someone be so kind as to tell me how I can do this?
« Last Edit: August 16, 2014, 01:17:57 pm by 10i »
Peppermint user since Fire / Ice
Re: sudo modprobe ndiswrapper at startup
« Reply #1 on: August 16, 2014, 11:59:15 am »
Run:
sudo gedit /etc/modules
when it opens, add a NEW line at the bottom that reads
ndiswrapper
SAVE the file .. reboot to test.
Any modules added in /etc/modules are loaded automagically at bootup
Offline 10i
Re: sudo modprobe ndiswrapper at startup (solved)
« Reply #2 on: August 16, 2014, 01:18:28 pm »
It works now thanks :)
« Reply #3 on: August 16, 2014, 01:41:38 pm »
No worries .. thanks for marking the topic solved :)
