Author Topic: from 9 to 10  (Read 319 times)
Offline Victorious
  • Peppermint version(s): peppermint 9 Ruspin-2 64bit
from 9 to 10
« on: May 28, 2019, 09:31:59 pm »
I have version 9 and want to load 10.  Unibootin won't open. I do not know what application opens it.  I am a newbie to Linux. Please help! Thanks! :'(
Re: from 9 to 10
« Reply #1 on: May 28, 2019, 09:38:26 pm »
I'm assuming you downloaded it, and when you click it it asks what you want to open it with ?
Try this...
Right-click the Unetbootin executable and select "Properties" .. select the "Permissions" tab .. put a tick in the box labelled "Allow executing file as a program" .. click the "Close" button.
Now try double-clicking the Unetbooting executable again .. did it start ?
BTW, welcome to the forum :)
Just out of interest though, can I ask why you're using Unetbootin when Peppermint 9 has a USB Image Writer pre-installed out of the box ?
« Last Edit: May 28, 2019, 09:42:34 pm by PCNetSpec »
