Author Topic: CPU scaling  (Read 545 times)
Offline neggard
CPU scaling
« on: May 28, 2019, 11:40:42 am »
I have search forum and internet for changing the governor to performace.
I have found some program like cpupower and cpufrequtils
But is peppermint 10 shipping with a cpu scaling utility already?
I want my cpu to always have governor performance.
Re: CPU scaling
« Reply #1 on: May 28, 2019, 11:55:57 am »
it does not - to the best of my knowledge.
That would fall under the guise of  "user choice" and not a "must have" to work
Both should be achievable though by following any tutorials on their respective installs
Offline neggard
Re: CPU scaling
« Reply #2 on: May 28, 2019, 02:47:12 pm »
I have tried many guides but no luck.
Re: CPU scaling
« Reply #3 on: May 28, 2019, 03:00:09 pm »
type this in a terminal
sudo apt-get install -y indicator-cpufreq
Reboot and then right click the icon in the Notifications area and choose either powersave or performance
Working here on Peppermint 10
ps I have no idea how to measure it to see if it actually does anything to the CPU power
Offline neggard
Re: CPU scaling
« Reply #4 on: May 28, 2019, 03:16:30 pm »
Thanks.
I use lscpu to see the speed. I have a  i7-4790, Base Frequency 3.60 GHz and  Max Turbo Frequency 4.00 GHz
The lscpu command give me 3.6 GHz when I have performance.
How could I set performace to be my default value at startup?
Is is possible to force the cpu to use the max turbo frequency all the time?
Re: CPU scaling
« Reply #5 on: May 28, 2019, 03:31:46 pm »
No idea - sorry
You will need to wait for the real clever members of the forum to reply
Re: CPU scaling
« Reply #6 on: May 28, 2019, 04:41:18 pm »
Maybe if you want to use it as a heater.
Re: CPU scaling
« Reply #7 on: May 28, 2019, 05:39:55 pm »
Why do you need this?!
You have an i7 quadcore with hyperthreading. Are you compiling from source a lot of large stuff?
Anyway, your call... try overclocking it, but its not any good for it.
Re: CPU scaling
« Reply #8 on: May 28, 2019, 05:51:29 pm »
I wouldn't want a CPU running flat out permanently (even worse in turbo mode permanently) .. modern CPU's are designed to automatically frequency scale depending on load, let it do its job.
You won't see a performance benefit of locking it to performance mode (it'll jump to that when needed anyway) .. you'll just be wasting electricity.
Offline neggard
Re: CPU scaling
« Reply #9 on: May 29, 2019, 02:35:15 pm »
Yes you are right, jthe CPU handle it good BUT
When you play high FPS games the CPU cant handle it fast enough, when that happend
the FPS drops fast and strange things happend in the game.
I am talking about CS:GO now (Counter-strike).
Many player want at least 300steady FPS.
