Author Topic: How to scan for WiFi (SOLVED)  (Read 1669 times)
Re: How to scan for WiFi
« Reply #15 on: May 29, 2019, 04:36:52 pm »
What's the output from:
cat /etc/modprobe.d/rtl8723de.conf
Offline Lin_Noob
« Reply #16 on: May 29, 2019, 04:43:04 pm »
operations rtl8723de ant_sel=2
« Reply #17 on: May 29, 2019, 07:31:44 pm »
I don't know if this is the problem (or if it's even right that is there at all), but (if anything) that should read
options rtl8723de ant_sel=2so run:
gksudo xed /etc/modprobe.d/rtl8723de.confchange it to read
options rtl8723de ant_sel=2SAVE the file and exit the text editor.
Now what happens when you run:
sudo modprobe rtl8723dedo you get any error ?
if not, does wireless work ?
If not, what's the output from:
modinfo rtl8723de
« Last Edit: May 29, 2019, 07:33:27 pm by PCNetSpec »
Offline Lin_Noob
« Reply #18 on: May 30, 2019, 07:54:22 pm »
aahhhh I thought that was it for sure, so I changed operations to options in the text ediotr and saved and exited and then I got this.
pep@pep-HP-Laptop-17-bs0xx ~ $ gksudo xed /etc/modprobe.d/rtl8723de.conf
(xed:7036): Gtk-CRITICAL **: 21:50:42.857: _gtk_widget_captured_event: assertion 'WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
(xed:7036): Gtk-CRITICAL **: 21:50:42.858: _gtk_widget_captured_event: assertion 'WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
** (xed:7036): WARNING **: 21:50:43.085: Set document metadata failed: Setting attribute metadata::xed-encoding not supported
** (xed:7036): WARNING **: 21:50:43.085: Set document metadata failed: Setting attribute metadata::xed-spell-language not supported
** (xed:7036): WARNING **: 21:50:45.895: Set document metadata failed: Setting attribute metadata::xed-position not supported
pep@pep-HP-Laptop-17-bs0xx ~ $ sudo modprobe rtl8723de
[sudo] password for pep:
modprobe: ERROR: could not insert 'rtl8723de': Operation not permitted
« Reply #19 on: May 31, 2019, 10:42:46 am »
Odd, can you give me the output from
modinfo rtl8723deas asked ?
and the output from
lsmod
BTW, you can safely ignore those xed warnings in the terminal.
« Last Edit: May 31, 2019, 11:17:21 am by PCNetSpec »
Offline Lin_Noob
« Reply #20 on: May 31, 2019, 02:05:36 pm »
Okay thanks,
I got
modinfo rtl8723de
filename:       /lib/modules/4.18.0-18-generic/updates/rtl8723de.ko
firmware:       rtlwifi/rtl8723defw.bin
description:    Realtek 8723DE 802.11n PCI wireless
license:        GPL
author:         Realtek WlanFAE <wlanfae@realtek.com>
author:         PageHe <page_he@realsil.com.cn>
srcversion:     225860B994CF8C6352A5C7A
alias:          pci:v000010ECd0000D723sv*sd*bc*sc*i*
depends:        rtlwifi,rtl_pci,btcoexist,rtl8723-common,phydm_mod
retpoline:      Y
vermagic:       4.18.0-18-generic SMP mod_unload
signat:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
parm:           dma64:bool
parm:           swenc:Set to 1 for software crypto (default 0) (bool)
parm:           ips:Set to 0 to not use link power save (default 1) (bool)
parm:           swlps:Set to 1 to use SW control power save (default 0) (bool)
parm:           fwlps:Set to 1 to use FW control power save (default 1) (bool)
parm:           msi:Set to 1 to use MSI interrupts mode (default 1) (bool)
parm:           aspm:Set to 1 to enable ASPM (default 0) (int)
parm:           debug_level:Set debug level (0-5) (default 0) (int)
parm:           debug_mask:Set debug mask (default 0) (ullong)
parm:           disable_watchdog:Set to 1 to disable the watchdog (default 0) (bool)
parm:           int_clear:Set to 0 to disable interrupt clear before set (default 0) (bool)
parm:           ant_sel:Set to 1 or 2 to force antenna number (default 0) (int)
pep@pep-HP-Laptop-17-bs0xx ~ $ lsmod
Module                  Size  Used by
rfcomm                 77824  16
cmac                   16384  1
bnep                   20480  3
nls_iso8859_1          16384  1
hp_wmi                 16384  0
mac80211              802816  0
wmi_bmof               16384  0
intel_wmi_thunderbolt    16384  0
cfg80211              667648  1 mac80211
uvcvideo               94208  0
videobuf2_vmalloc      16384  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         24576  1 uvcvideo
videobuf2_common       40960  2 videobuf2_v4l2,uvcvideo
videodev              188416  3 videobuf2_v4l2,uvcvideo,videobuf2_common
media                  40960  2 videodev,uvcvideo
snd_hda_codec_hdmi     49152  1
snd_hda_codec_realtek   106496  1
snd_hda_codec_generic    73728  1 snd_hda_codec_realtek
intel_rapl             20480  0
x86_pkg_temp_thermal    16384  0
intel_powerclamp       16384  0
coretemp               16384  0
kvm                   626688  0
irqbypass              16384  1 kvm
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
pcbc                   16384  0
aesni_intel           200704  2
aes_x86_64             20480  1 aesni_intel
crypto_simd            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel,aesni_intel
glue_helper            16384  1 aesni_intel
intel_cstate           20480  0
intel_rapl_perf        16384  0
i915                 1740800  12
joydev                 24576  0
input_leds             16384  0
serio_raw              16384  0
btusb                  45056  0
btrtl                  16384  1 btusb
btbcm                  16384  1 btusb
btintel                20480  1 btusb
snd_soc_skl           102400  0
bluetooth             552960  45 btrtl,btintel,btbcm,bnep,btusb,rfcomm
snd_soc_skl_ipc        61440  1 snd_soc_skl
snd_soc_sst_ipc        16384  1 snd_soc_skl_ipc
snd_soc_sst_dsp        32768  1 snd_soc_skl_ipc
snd_hda_ext_core       24576  1 snd_soc_skl
ecdh_generic           24576  2 bluetooth
snd_soc_acpi           16384  1 snd_soc_skl
snd_soc_core          229376  1 snd_soc_skl
wmi                    24576  3 hp_wmi,intel_wmi_thunderbolt,wmi_bmof
snd_compress           20480  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_intel          40960  3
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core           81920  7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_skl
intel_vbtn             16384  0
drm_kms_helper        172032  1 i915
snd_hwdep              20480  1 snd_hda_codec
snd_pcm                98304  8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
drm                   458752  13 drm_kms_helper,i915
sparse_keymap          16384  2 hp_wmi,intel_vbtn
int3400_thermal        16384  0
snd_timer              32768  1 snd_pcm
snd                    81920  16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
i2c_algo_bit           16384  1 i915
mac_hid                16384  0
intel_pch_thermal      16384  0
soundcore              16384  1 snd
mei_me                 40960  0
fb_sys_fops            16384  1 drm_kms_helper
syscopyarea            16384  1 drm_kms_helper
processor_thermal_device    16384  0
sysfillrect            16384  1 drm_kms_helper
hp_wireless            16384  0
intel_soc_dts_iosf     16384  1 processor_thermal_device
sysimgblt              16384  1 drm_kms_helper
acpi_thermal_rel       16384  1 int3400_thermal
mei                    98304  1 mei_me
int3403_thermal        16384  0
video                  45056  1 i915
int340x_thermal_zone    16384  2 int3403_thermal,processor_thermal_device
acpi_pad              180224  0
sch_fq_codel           20480  3
sunrpc                352256  1
parport_pc             36864  0
ppdev                  20480  0
lp                     20480  0
parport                49152  3 parport_pc,lp,ppdev
ip_tables              28672  0
x_tables               40960  1 ip_tables
autofs4                40960  2
btrfs                1163264  0
xor                    24576  1 btrfs
zstd_compress         163840  1 btrfs
raid6_pq              114688  1 btrfs
libcrc32c              16384  1 btrfs
ahci                   40960  2
psmouse               151552  0
r8169                  86016  0
libahci                32768  1 ahci
mii                    16384  1 r8169
« Last Edit: May 31, 2019, 03:11:40 pm by PCNetSpec »
« Reply #21 on: May 31, 2019, 03:09:45 pm »
Okay type
sudo modprobe rtl8723deand hit enter
you will be prompted for your password .. type it, then hit enter.
Be aware you won't see anything echoed to screen when typing your password (not even ******) but it is going in, so just type it and hit enter.
did you still get the
edrror ?
« Last Edit: May 31, 2019, 03:12:22 pm by PCNetSpec »
Offline Lin_Noob
« Reply #22 on: June 01, 2019, 10:19:39 am »
Yep, I got the same output :(
« Reply #23 on: June 01, 2019, 10:42:45 am »
dkms status
Offline Lin_Noob
« Reply #24 on: June 01, 2019, 11:29:57 am »
dkms status
rtlwifi-new, 0.6, 4.18.0-18-generic, x86_64: installed (original_module exist
« Reply #25 on: June 01, 2019, 01:42:38 pm »
Run these commands in sequence (with an active internet connection):
sudo apt-get install dkms gitthen
sudo rm -v /etc/modprobe.d/rtl8723de.confthen
sudo dkms uninstall rtlwifi-new/0.6then
sudo dkms remove rtlwifi-new/0.6 --allthen
mkdir ~/Realtek-rtl8723dethen
cd ~/Realtek-rtl8723dethen
sudo git clone https://github.com/smlinux/rtl8723de.git -b 4.15-upthen
sudo dkms add ./rtl8723dethen
sudo dkms install rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414then
sudo depmod -anow does running
sudo modprobe rtl8723dework, and did wireless spring to life ?
If so, does it survive a reboot ?
TO UNINSTALL
sudo rmmod 8723dethen
sudo dkms uninstall rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414then
sudo dkms remove rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414 --all
« Last Edit: June 04, 2019, 01:27:08 am by PCNetSpec »
Offline Lin_Noob
« Reply #26 on: June 02, 2019, 06:13:19 pm »
It works! Thanks so much dude! I don't understand all that wizardry but it's working perfectly now.
Thanks so much man.
« Reply #27 on: June 03, 2019, 06:05:53 am »
You're most welcome, glad I could help :)
Can you please remember to mark your topics (SOLVED) when you consider them so. You can do this by editing the FIRST posting in your topic and appending (SOLVED) to the subject line.
TIA :)
PS. I've done this one for you.
Offline Lin_Noob
Re: How to scan for WiFi (SOLVED)
« Reply #28 on: June 03, 2019, 03:50:03 pm »
I’m sorry, tagging this as solved was the first thing I tried to do once I connected to my WiFi but I couldn’t find the edit button... lol thanks again!
