Author Topic: Pepp 10 Terminal - Up arrow to step through previous commands.  (Read 540 times)
Offline GEMS
On previous versions of Peppermint; the up arrow would allow you to step through previous commands instead of retyping them.
My recent installation of Pepp10 is not doing that. Are there commands to enable the response?
Thanks in advance.
GEMS.
Re: Pepp 10 Terminal - Up arrow to step through previous commands.
« Reply #1 on: May 25, 2019, 11:02:48 am »
That should just work .. it hasn't been changed in Peppermint 10
Offline GEMS
« Reply #2 on: May 25, 2019, 03:29:03 pm »
Thanks. I will redo.
GEMS.
« Reply #3 on: May 26, 2019, 03:00:32 am »
If you have lots to scroll back through
type
history in the terminal
it will then list all the commands you have used with a number next to them
simply type the ! followed by the number relevant to the command  ie !34 and that command will execute.
