Author Topic: Problems with darktable installation  (Read 900 times)
Offline pete051
« on: May 21, 2019, 07:49:59 am »
My first attempt was with apt-get install which worked but no icon in the menu meaning I could only launch it from either the command line or the software manager so I tried to reinstall with both software manager and synaptic same result, I've tried uninstalling and reinstalling with synaptic (software manager seems a tad clunky) but with the same result. Any ideas? thanks in advance :)
Re: Problems with darktable installation
« Reply #1 on: May 21, 2019, 08:16:59 am »
Can you post the output from:
dpkg -l | grep tableand
snap listand
flatpak list
Offline pete051
« Reply #2 on: May 21, 2019, 08:43:15 am »
ii  dmidecode                                     3.1-1                                           amd64        SMBIOS/DMI table decoder
ii  iptables                                      1.6.1-2ubuntu2                                  amd64        administration tools for packet filtering and NAT
ii  kbd                                           2.0.4-2ubuntu1                                  amd64        Linux console font and keytable utilities
ii  libboost-thread1.65.1:amd64                   1.65.1+dfsg-0ubuntu5                            amd64        portable C++ multi-threading
ii  libdvbpsi10:amd64                             1.3.2-1                                         amd64        library for MPEG TS and DVB PSI tables decoding and generating
ii  libevent-2.1-6:amd64                          2.1.8-stable-4build1                            amd64        Asynchronous event notification library
ii  libhtml-tagset-perl                           3.20-3                                          all          Data tables pertaining to HTML
ii  libnatpmp1                                    20150609-2                                      amd64        portable and fully compliant implementation of NAT-PMP
ii  libnspr4:amd64                                2:4.18-1ubuntu1                                 amd64        NetScape Portable Runtime Library
ii  libportaudio2:amd64                           19.6.0-1                                        amd64        Portable audio I/O - shared library
ii  libsigsegv2:amd64                             2.12-1                                          amd64        Library for handling page faults in a portable way
ii  libupnp6:amd64                                1:1.6.24-4                                      amd64        Portable SDK for UPnP Devices, version 1.6 (shared libraries)
ii  libxtables12:amd64                            1.6.1-2ubuntu2                                  amd64        netfilter xtables library
ii  python3-netifaces                             0.10.4-0.1build4                                amd64        portable network interface information - Python 3.x
pete@pete-SATELLITE-C855-17R:~$ snap list
No snaps are installed yet. Try 'snap install hello-world'.
pete@pete-SATELLITE-C855-17R:~$ flatpak list
Ref                                                Options
com.dropbox.Client/x86_64/stable                   system,current
org.freedesktop.Platform.VAAPI.Intel/x86_64/18.08  system,runtime
org.freedesktop.Platform.html5-codecs/x86_64/18.08 system,runtime
org.gnome.Platform/x86_64/3.32                     system,runtime
« Reply #3 on: May 21, 2019, 09:00:48 am »
So darktable isn't installed at the moment ?
Run:
sudo apt-get install darktablenow let me know if it's in the menu at
Menu > Graphics > Darktable
« Last Edit: May 21, 2019, 09:11:55 am by PCNetSpec »
Offline pete051
« Reply #4 on: May 21, 2019, 09:13:35 am »
Yes Darktable is installed if I type darktable in a terminal it appears but no it's not in the graphics menu sudo apt-get install darktable was the first thing I tried :)
« Reply #5 on: May 21, 2019, 09:15:40 am »
Did you just run that command I gave you to install it ? .. because according to your earlier output it was NOT installed ?
What is the output from:
dpkg -l | grep darktablenow ?
Offline pete051
« Reply #6 on: May 21, 2019, 09:21:14 am »
ii  darktable                                     2.4.2-1                                         amd64        virtual lighttable and darkroom for photographers
But I think I may have found the problem after installing peppermint I used an old backup to repopulate the hard drive and
there were some old darktable config file on that, I think that could be causing the problem so I intend to uninstall darktable delete that folder and try again
« Reply #7 on: May 21, 2019, 09:27:00 am »
An old darktable config directory may stop it from launching, but it's unlikely to stop it displaying in the menu (unless you've broken the menu configs themselves by copying older versions of those too ?) .. the only thing (besides a broken menu)  likely to stop it showing in the menu is if you have a broken launcher for it.
What's the output from:
ls ~/.local/share/applicationsand
ls /usr/share/applications | grep dark
« Last Edit: May 21, 2019, 09:36:20 am by PCNetSpec »
Offline pete051
« Reply #8 on: May 23, 2019, 12:19:56 pm »
No it's till not playing
betterthanchess.desktop
chrome-aapocclcgogkmnckokdopfmhonfmgoek-Default.desktop
chrome-aohghmighlieiainnegkcijnfilokake-Default.desktop
chrome-apdfllckaahabafndbhieahigkjlhalf-Default.desktop
chrome-blpcfgokakmgnkcojhhkbfbldkacnbeo-Default.desktop
chrome-coobgpohoikkiipiblmjeljniedjpjpf-Default.desktop
chrome-djonnbgfieijldcieafgjcnhmpcfpmgg-Default.desktop
chrome-felcaaldnbdncclmgdcncolpebgiejap-Default.desktop
chrome-fgdgokchhicmaiacmgegjnppjkgogdhm-Default.desktop
chrome-hmjkmjkepdijhoojdojkdfohbdgmmhki-Default.desktop
chrome-jccchjobcggajhnmckffhcahkkbioifn-Default.desktop
chrome-pjkljhegncpnkpknbcohdijeoejaedia-Default.desktop
darktable.desktop
darktable-git.desktop
editorbypixlr.desktop
entanglement.desktop
expressbypixlr.desktop
firefoxsend.desktop
firstpersontetris.desktop
gmail.desktop
googlecalendar.desktop
googledrive.desktop
mahjong.desktop
microsoftexcelonline.desktop
microsoftonenoteonline.desktop
microsoftpowerpointonline.desktop
microsoftwordonline.desktop
mimeapps.list
onlineuserguide.desktop
peppermintforum.desktop
solitaire.desktop
spidersolitaire.desktop
SATELLITE-C855-17R:~$ ls /usr/share/applications | grep dark
darktable.desktop
« Reply #9 on: May 23, 2019, 12:27:58 pm »
Run:
rm ~/.local/share/applications/darktable.desktopthen
rm ~/.local/share/applications/darktable-git.desktopnow is darktable in the menu ?
Offline pete051
« Reply #10 on: May 24, 2019, 08:16:25 am »
That fixed it :) thanks a lot :)
« Reply #11 on: May 24, 2019, 09:40:58 am »
No problem, glad I could help :)
