Author Topic: Querying Ink level using Ink and libinklevel ( solved )  (Read 3159 times)
Offline Grem41
  • Peppermint version(s): 3
« on: August 14, 2014, 12:36:15 pm »
Hi all, hope someone can help.
I'm trying to query the level of ink (Remanufactured ink cartridge) in my HP printer C4585.
Through various research ( http://libinklevel.sourceforge.net/ )I found and installed the 2 programs to obtain this detail. These being
1.           Ink  installed using sudo apt-get install ink
2.          Libinklevel ( an associated library install in turn by Ink
However when I run ink -p usb it responds as follows
Could not access '/dev/usb/lp0' or '/dev/usblp0'.
Could not get ink level.
I know I need to change the permissions somewhere but how ?
Thanks
« Last Edit: August 29, 2014, 04:52:55 pm by Grem41 »
Re: Querying Ink level using Ink and libinklevel
« Reply #1 on: August 14, 2014, 01:49:30 pm »
Doesn't hplip-gui give ink levels for Printers ?
What's the output from:
ls -l /dev/usb
groups
Offline Grem41
« Reply #2 on: August 16, 2014, 07:12:56 am »
Hi PCNetSpec
In response to your questions
 1.   Doesn't hplip-gui give ink levels for Printers ?
      Unfortunately it only gives approximate value ie very low low etc  not percentages that I want
2.
ls -l /dev/usb
yields the following results yesterday
      total 0
      crw-rw---- 1 root lp 180, 0 Aug 15 21:07 lp0
3.
groups
yields
      steve adm cdrom sudo dip plugdev lpadmin sambashare
4.   Followed the video, it solved the problem  :) by showing at around 1.00 - 2.34 in I found I needed to change the permissions for everyone using
  sudo chmod 666 /dev/usb/lp0
As an aside what is lp0 I take its the line printer but I use usb ?
Lastly I found Ink doesn't support HP C4500 series and only shows 0% for the black cartridge but that cannot be since its a new remanufactured cartridge was just installed but not HP genuine. Very frustrating
« Reply #3 on: August 16, 2014, 12:09:11 pm »
Can't really help if it's not supported ;)
(or the chip added in the re-manufacture process isn't supported)
You'll find ink levels are quess work anyway .. and AFAIK based on number of pages printed, and a guess based on average coverage.
No ink cartridges actually contain a float like a petrol tank as the ink is absorbed in foam.
There's no such thing as an accurate ink level monitor (irrespective of OS).
Offline Grem41
« Reply #4 on: August 18, 2014, 07:47:41 am »
As mentrioned in my last post with your help was able to run ink -p usb without the error message (see 1st post)
Below is a terminal copy to resolve this issue which works fine
steve@steve-Packard-Bell-EasyNote ~ $ ls -l /dev/usb
total 0
crw-rw-rw- 1 root lp 180, 0 Aug 18 11:43 lp0
steve@steve-Packard-Bell-EasyNote ~ $ groups
steve@steve-Packard-Bell-EasyNote ~ $ sudo chmod 666 /dev/usb/lp0
[sudo] password for steve:
steve@steve-Packard-Bell-EasyNote ~ $ ink -p usb
ink 0.5.1 (c) 2010 Markus Heinz
HP Photosmart C4500 series
Black:                          0%
Color:                          0%
However on reboot it fails to run ink -p usb and I get the original error message
Why ?
« Reply #5 on: August 21, 2014, 12:27:23 pm »
The usb device gets recreated every boot, so without adding a custom udev rule you'll have to change permissions or owner every boot.
try adding yourself to the "lp" group.
« Last Edit: August 21, 2014, 12:29:26 pm by PCNetSpec »
Offline Grem41
« Reply #6 on: August 26, 2014, 11:19:30 am »
I see why now. so attempting to learn about groups --- You said
How do I go about this
I found a mention of this, in a ubuntu forum see http://ubuntuforums.org/showthread.php?t=1928567
From that I believe I need to enter
sudo adduser steve lp
Is this correct?
« Reply #7 on: August 26, 2014, 11:42:15 am »
as both the user and group already exist, the command would be:
sudo usermod -a -G lp steve
but be VERY careful with the syntax.
A MUCH safer way to add the user "steve" to the gropup "lp" would be to go to:-
menu > System Tools > Users and Groups
Click the "Manage Groups" button
Scroll down and hightlight "lp" in the list of groups .. then click the "Properties" button.
Then make sure there's a tick next to "steve" .. then click "OK"
Then log off/on again. (or reboot) <-- IMPORTANT
Once logged back on you can see which groups "steve" belongs to with:
groups steve
Offline Grem41
« Reply #8 on: August 29, 2014, 04:52:11 pm »
Your advice worked a treat. Will mark the topic solved.
Thanks
Re: Querying Ink level using Ink and libinklevel ( solved )
« Reply #9 on: August 29, 2014, 05:19:05 pm »
No problem, and thanks for marking the topic solved :)
