Author Topic: disable login after resume from suspend  (Read 399 times)
Offline htnakirs
« on: May 20, 2019, 02:48:15 am »
i am running a live version of 10 off the ram using the "toram" option on a system with 8gb. works great.
2 hassles though :
1. i have disabled "ask for password" under settings, but i dont find an option to disable the login screen itself.
i would like to return to the desktop directly on resume without having to type the username.
2. is there any way to suspend directly on pressing the power button without the power menu popping up and seeking input?
thanks
Re: disable login after resume from suspend
« Reply #1 on: May 24, 2019, 05:33:39 pm »
Does going to
Menu > Settings > Light Locker Settings
and changing
Automatically lock the screen: Never
make any difference ?
Offline Johan
« Reply #2 on: May 25, 2019, 01:48:24 am »
Does going to
and changing
Tried it, but still needs a password. Same with Enable light locker ticked off.
« Reply #3 on: May 25, 2019, 05:18:08 am »
You probably have to remove light locker to stop that.
Offline Johan
« Reply #4 on: May 25, 2019, 11:52:57 am »
Probably, but I don't mind typing the password after suspend or locked screen. I like typing on my CoolerMaster keyboard  8)
