Author Topic: An error occurred (Solved)  (Read 590 times)
Offline kloos
  • Fairly new at Linux
« on: May 17, 2019, 10:16:43 am »
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open() failed, please report.
I try running it but it says i need super-user privileges.
It happened whilst trying to install Bluefish from the software.
Help  >:(
« Last Edit: May 17, 2019, 10:21:57 am by kloos »
Re: An error occurred
« Reply #1 on: May 17, 2019, 10:19:13 am »
Super-user privileges means use sudo before the command.
sudo dpkg --configure -a
Offline kloos
Re: An error occurred (Solved)
« Reply #2 on: May 17, 2019, 10:22:28 am »
Thanks, I love it when they're easy  :D
« Reply #3 on: May 17, 2019, 10:37:57 am »
You're welcome, thanks for marking it solved.  :)
