Author Topic: Trouble booting an iMac running P9  (Read 959 times)
Offline kimtoufectis
  • Peppermint version(s): 7
« on: May 14, 2019, 08:50:18 pm »
My venerable Intel Core Duo iMac (early 2006, with an SSD) has been running P9 for some time (and P7 and P8 before that), but something recently seems to have broken the boot process.
(Re)booting leads to a nearly-black background, but instead showing of the Peppermint logo and progress bar reflecting a normal boot, it just sticks at that background.  Killing it by holding the power button, the next reboot takes me to a menu offering options including booting or memory tests.  My metal Mac keyboard isn't recognized until the boot finishes, so I leave it 20 or 30 seconds and it boots as if nothing was wrong.  I experience this tedious multi-step process any time I start it up.
Any guidance for a not-so-Linux-savvy user (otherwise pleased with Peppermint) willing to follow detailed instructions?
Re: Trouble booting an iMac running P9
« Reply #1 on: May 15, 2019, 03:10:53 am »
Are we talking about 32bit or 64bit Peppermint ?
and can you post the output from
df -hand
blkidand
sudo fdisk -land
dpkg -l | grep grub
« Last Edit: May 15, 2019, 03:20:47 am by PCNetSpec »
« Reply #2 on: May 15, 2019, 12:59:11 pm »
It's the 32 bit version.
Here are the results of those commands:
kim@kim-iMac ~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            981M     0  981M   0% /dev
tmpfs           200M  2.2M  198M   2% /run
/dev/sda2       117G   15G   97G  14% /
tmpfs           999M   45M  954M   5% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           999M     0  999M   0% /sys/fs/cgroup
/dev/loop0       86M   86M     0 100% /snap/core/6530
/dev/loop1       86M   86M     0 100% /snap/core/6675
/dev/loop2      165M  165M     0 100% /snap/midori/389
/dev/loop3       86M   86M     0 100% /snap/core/6813
/dev/loop4      166M  166M     0 100% /snap/midori/452
tmpfs           200M   24K  200M   1% /run/user/1000
kim@kim-iMac ~ $ blkid
/dev/sda2: UUID="fe2b556f-ad4a-42b9-b3ec-390d22f736bc" TYPE="ext4" PARTUUID="301e5b61-8ffe-4fc9-8814-880c7f582cbe"
kim@kim-iMac ~ $ sudo fdisk -l
[sudo] password for kim:
Disk /dev/loop0: 85.7 MiB, 89862144 bytes, 175512 sectors
Disk /dev/loop1: 85.6 MiB, 89735168 bytes, 175264 sectors
Disk /dev/loop2: 165 MiB, 172961792 bytes, 337816 sectors
Disk /dev/loop3: 85.7 MiB, 89800704 bytes, 175392 sectors
Disk /dev/loop4: 165.4 MiB, 173387776 bytes, 338648 sectors
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Disklabel type: gpt
Disk identifier: 2716BAEC-6E1C-4111-8BAA-9E2AAB025FB6
Device     Start       End   Sectors   Size Type
/dev/sda1   2048      4095      2048     1M BIOS boot
/dev/sda2   4096 250068991 250064896 119.2G Linux filesystem
kim@kim-iMac ~ $ dpkg -l | grep grub
ii  grub-common                           2.02-2ubuntu8.13                                i386         GRand Unified Bootloader (common files)
ii  grub-gfxpayload-lists                 0.7                                             i386         GRUB gfxpayload blacklist
ii  grub-pc                               2.02-2ubuntu8.13                                i386         GRand Unified Bootloader, version 2 (PC/BIOS version)
ii  grub-pc-bin                           2.02-2ubuntu8.13                                i386         GRand Unified Bootloader, version 2 (PC/BIOS binaries)
ii  grub2-common                          2.02-2ubuntu8.13                                i386         GRand Unified Bootloader (common files for version 2)
kim@kim-iMac ~ $
« Reply #3 on: May 17, 2019, 05:50:23 am »
Okay, terminal outputs all provided...any advice on how to restore a normal boot?
« Reply #4 on: May 24, 2019, 02:22:39 pm »
Okay, hearing nothing in response to two messages, I figured I'd see if installing P10 might resolve my problem.  No such luck, so I'm still in need of some good advice.  Still trying to install Peppermint onto a 32-bit Intel Core Duo iMac (early 2006).
I can insert the P10 DVD-ROM I burned of the 32 bit P10, and run it from the disk.  When I choose install, it begins the process and I choose "erase the disk and install P10" and it comes back with a dialog box:
"No EFI System Partition was found.  This system will likely not be able to boot successfully, and the installation process may fail.  Please go back and add an EFI System Partition, or continue at your own risk."
Going back takes me into the partitioning tool, where I am lost.  It shows:
Device                                Size                    Used
/dev/sda
  free space                        (1 MB)                 unknown
  /dev/sd1/ biosgrub        (1 MB)                 unknown
  /dev/sd2/  ext4          /  (128033 MB)
  free space                        (0 MB)
Any guidance avaiable?
« Reply #5 on: May 24, 2019, 02:28:33 pm »
If your Mac can only use a GPT partition scheme and EFI booting then you're probably out of luck because 32-bit Peppermint won't install in EFI mode.
