Author Topic: How to Decide Wireless Keyboard and Mouse for PM  (Read 720 times)
Offline rajeev2631007
« on: April 16, 2019, 12:52:19 am »
Hi,
I'm looking for compact Wireless keyboard and mouse for PM8. If I go for online stores in India there is very few vendor mentioned it is compatible with Linux. There is any way to find which product and model compatible with Linux.What should I consider to buy wireless keyboard and mouse for Linux.
How could we select different layout and model in PM OS.
I had short listed one Logitech K400 Plus Wireless Keyboard. How can I find out it is compatible with PM.
https://www.amazon.in/Logitech-K400-Wireless-Keyboard-Black/dp/B014EUQOGK?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duc11-21&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B014EUQOGK
Please advice.
Rajeev Gautam
Re: How to Decide Wireless Keyboard and Mouse for PM
« Reply #1 on: April 16, 2019, 01:21:54 am »
Personally, I would check the user comments, filtered with the word "Ubuntu".
I only saw a few comments on the dot .in web page. However, on the dot .com web page, there are 2-pages of mostly positive comments:
LINK: https://www.amazon.com/Logitech-K400-Wireless-Keyboard-Black/product-reviews/B014EUQOGK/ref=cm_cr_arp_d_viewopt_kywd?showViewpoints=1&pageNumber=1&filterByKeyword=ubuntu
« Reply #2 on: April 16, 2019, 08:44:45 am »
You can take its compatibility as gospel .. I have a K400 Plus connected to my Peppermint KODI box, and it works perfectly :)
You may also want to read this generic post concerning USB wireless mice and keyboards
https://forum.peppermintos.com/index.php/topic,8083.msg82764.html#msg82764
« Reply #3 on: April 16, 2019, 05:53:43 pm »
I've found Logitech is often good to use for Linux.
I have a K400r that works great. I usually use it for my Steam Machine, which is running Peppermint 7. I'm presently using another Linux distribution and using it (to make sure it works) to type this message. It's almost the same thing as that K400 Plus you linked to. I filtered the results in the Amazon reviews for the K400 Plus to "Ubuntu" and there are a lot of people who are using it for Ubuntu.
« Last Edit: April 16, 2019, 05:57:07 pm by scifidude79 »
Re: How to Decide Wireless Keyboard and Mouse for PM-Solved
« Reply #4 on: April 17, 2019, 12:27:36 am »
Thanks you everybody for your kind input and suggestion. :P
Offline rayzer
  • Onnnn the Pep 10..
« Reply #5 on: April 17, 2019, 01:34:19 pm »
i have a hp x4000 wireless mouse which has worked flawless with every windows and linux os ive tried. mines a bit battered by now but ill probably pick up a generic one next time. get something with standard plug n play drivers. i also have a logitech keyboard but the media keys dont work on some distros but im not too fussed as i rarely every use them.
For wallpapers ive made you can download them here https://flickr.com/photos/92410488@N03/
