Author Topic: Shutdown freeze (POSSIBLE DEF SOLUTION)  (Read 995 times)
Offline DARKBOW923
  • All linux problem have solutions.
  • Peppermint version(s): Peppermint 7 64 bit :D
« on: March 30, 2019, 03:46:02 am »
Hello all.
Today, i finnaly solved my problem with linux, the shutdown.
I know i maked an other post with a posible solution, but after peppermint os 7 that solution i found doesn't work for me at all. (Im now in PM9)
So, after 1 year of investigating the problem, (is not a joke)  i found a solution (or a possible really definitive solution).
Well, the things i made was that:
Go to
/etc/default/grub
Then, put this line:
noapic acpi=force reboot=b
Then i updated the PM9 kernel 4.15 to 5.0 using uuku
Ok, then i go to BIOS and i set the ACPI enabled and the wake up for USB DISABLED.
Finally, i maked an
update-grub and all should be 100% fine.
That method FINNALY works for me, So its probably that it workds for you too.
« Last Edit: April 03, 2019, 12:13:10 am by DARKBOW923 »
Now with new machine! Medion AKOYA intel core i3 7100 3mb caché 7th gen, 4GB RAM DDR4 Intel HD Graphics 630 1TB HDD space.
Re: Shutdown freeze (POSSIBLE DEF SOLUTION)
« Reply #1 on: March 30, 2019, 04:08:09 am »
Thx for sharing  :)
« Reply #2 on: March 30, 2019, 08:27:26 pm »
If you hit the Esc key whilst the system is shutting down, does it give a clue where shutdown is hanging ?
Offline DARKBOW923
« Reply #3 on: April 03, 2019, 12:06:44 am »
Hi bro!
No, the funny thing when PM freeze on shutdown is that you CAN'T hit any key/use mouse, it just freeze completily.
But i found this method (im gonna edit the post) and now i can shutdown PM correctly.
« Reply #4 on: April 03, 2019, 06:14:43 am »
Cool .. at least you've found a solution, which is the main thing :)
