Author Topic: How get desktop icons (SOLVED)  (Read 1623 times)
Offline theedude
« on: March 28, 2019, 12:02:15 pm »
On other Distros/DE's I've used, there is usually a shortcut to home, trash, mounted drives, etc. on the desktop. I dont see this on mine. Maybe there is a way to enable this, but I couldn't find it.
« Last Edit: March 28, 2019, 01:30:19 pm by PCNetSpec »
Re: How get desktop icons
« Reply #1 on: March 28, 2019, 01:23:07 pm »
Fire up "dconf Editor" by navigating to:-
Menu > System > dconf Editor
Then in dconf Editor, navigate to org > nemo > desktop
Then toggle ON/OFF any of:-
computer-icon-visible
home-icon-visible
network-icon-visible
trash-icon-visible
volumes-visible
Or from the command line....
Computer icon ON
gsettings set org.nemo.desktop computer-icon-visible trueComputer icon OFF
gsettings set org.nemo.desktop computer-icon-visible false
Home folder icon ON
gsettings set org.nemo.desktop home-icon-visible trueHome folder icon OFF
gsettings set org.nemo.desktop home-icon-visible false
Network icon ON
gsettings set org.nemo.desktop network-icon-visible trueNetwork icon OFF
gsettings set org.nemo.desktop network-icon-visible false
Trash icon ON
gsettings set org.nemo.desktop trash-icon-visible trueTrash icon OFF
gsettings set org.nemo.desktop trash-icon-visible false
Show icons for mounted volumes ON
gsettings set org.nemo.desktop volumes-visible trueShow icons for mounted volumes OFF
gsettings set org.nemo.desktop volumes-visible false
« Last Edit: March 28, 2019, 01:27:27 pm by PCNetSpec »
Offline theedude
Re: How get desktop icons (SOLVED)
« Reply #2 on: March 28, 2019, 01:26:55 pm »
Perfect. Thanks.
« Reply #3 on: March 28, 2019, 01:29:14 pm »
You're most welcome :)
Please remember to append (SOLVED) to the subject line of the FIRST posting in your topic .. not the LAST posting ;)
(other wise the topic name doesn't change in the forum menus)
I've done this one for you.
« Last Edit: March 28, 2019, 01:31:27 pm by PCNetSpec »
