Author Topic: Pop Peeper Links  (Read 433 times)
Offline peppycrab
Pop Peeper Links
« on: March 26, 2019, 11:57:38 pm »
I am running Pop Peeper thru Wine. By default, it opens links in "Wine Windows Explorer".   WWE is not accepted by some sites. There is an option to change to an external browser, but I'm assuming it expects an exe file. If I want links to open in Chromium, where do I find it's exe equivalent?
Re: Pop Peeper Links
« Reply #1 on: March 27, 2019, 09:51:20 am »
Try doing a google search for "chromium for windows". You would be amazed by what you can find by doing google searches.  :D
Offline peppycrab
« Reply #2 on: March 27, 2019, 01:53:22 pm »
I have Chromium on my P8 Respin. Biut I don't know what the initiation file is or where to find it. In other words, the exe - equivalent.
« Reply #3 on: March 27, 2019, 05:12:01 pm »
You can't use the Linux version of a web browser in WINE .. theoretically you could install the Windows version of say Chrome inside WINE (and make it the default browser for WINE), but I'm not sure how to do that or if it would work with your other WINE app .. you'd probably be better served asking this on the WINE forum.
« Reply #4 on: March 27, 2019, 05:14:07 pm »
https://chromium.woolyss.com/
The Windows binaries are down the page, past Linux and BSD.
« Reply #5 on: March 27, 2019, 05:22:28 pm »
Chromium Woolies .. I bet they're scratchy ???
« Reply #6 on: March 27, 2019, 05:34:24 pm »
And hot.
Offline peppycrab
« Reply #7 on: March 27, 2019, 09:12:37 pm »
I think the problem is in Pop Peeper itself. Most , but not all of it's functions work thru Wine. I tried a stand-alone browser with an exe extension.....no joy.
A PITA workaround - I cut the URL from Wine Internet Explorer and paste into the URL bar of Chromium. I guess that's my only solution.
