Author Topic: Wallpapers for the Pep  (Read 6966 times)
Offline rayzer
  • Graphics n Stuff
« on: March 20, 2019, 04:58:31 pm »
UPDATE: Wallpaper links are now in signature area under my posts
edited a wallpaper i download a while back and put some peppermint stuff into it, basic job but looks ok i think
(image tags not working for me for some reason, feel free to edit)
https://imgur.com/a/P3WhXrR
(click image to enlarge)
« Last Edit: June 06, 2020, 01:07:17 pm by rayzer »
Re: Wallpaper for the Pep
« Reply #1 on: March 21, 2019, 12:41:18 am »
Hi rayzer,
Great wallpaper !!  8)
« Reply #2 on: March 21, 2019, 10:11:35 am »
Go to your link
On IMGUR, right-click the image and select "Copy Image Location" .. come back here, and in the forum editor right-click and select "Paste" .. then surround the resulting URL with IMG tags .. so you end up with:-
[img]https://i.imgur.com/HFHXdys.png[/img]or
[center][img]https://i.imgur.com/HFHXdys.png[/img][/center]if you also want it centred...
The image will now display inline in your post on this forum.
I've done this one for you :)
« Last Edit: March 21, 2019, 10:21:39 am by PCNetSpec »
Offline rayzer
  • Graphics n Stuff
« Reply #3 on: March 21, 2019, 12:19:43 pm »
thanks, i was just trying to wrap the original link instead of your pasted one and it kept appearing blank.
Offline rayzer
  • Graphics n Stuff
« Reply #4 on: May 07, 2019, 11:33:09 am »
another quick job, gimps been a chab though
« Last Edit: May 07, 2019, 11:36:39 am by rayzer »
« Reply #5 on: May 07, 2019, 11:37:35 am »
Looking good  8)
Offline rayzer
  • Graphics n Stuff
« Reply #6 on: May 08, 2019, 12:30:39 pm »
another one, works nice with dark themes. right click > view image and save
Offline clatterfordslim
« Reply #7 on: May 08, 2019, 06:57:32 pm »
Got it on my Elitebook, lovely jubbly. ;D
But so is this Forum :)
« Reply #8 on: May 09, 2019, 01:09:10 am »
Hi rayzer,
I really like the darker (last posted image) wallpaper! Nice work!  8)
Offline Johan
« Reply #9 on: May 18, 2019, 03:30:55 am »
Check out the new Pepp 10 walls by Karl Schneider wich look absolutely beautifull and the 4 new ones by Ray Bilcliff also very nice ;)
« Last Edit: May 18, 2019, 05:14:44 am by Johan »
« Reply #10 on: May 18, 2019, 05:24:33 am »
Hi Johan,
I know those already, as I am on the testing team for the beta and release candidates for Peppermint 10  ;)
But thanks anyway, because others need to check them out too.  8)
« Reply #11 on: May 18, 2019, 05:58:23 am »
Here are the 2 new Karl Schneider Peppermint 10 wallpapers .. for those that may want them in an earlier version of Peppermint:-
All images are 3840 x 2160 (aka. 4K) png's .. so expect them to take a while to render here if you have a slow connection (or our server is under load).
(I could have used say IMGUR, but that converts them to jpg to save space .. but they don't look as good as jpg's)
and the new login/lock screen background:-
« Last Edit: May 18, 2019, 06:09:39 am by PCNetSpec »
Offline rayzer
  • Graphics n Stuff
« Reply #12 on: May 19, 2019, 02:41:59 pm »
ive already downloaded pep10 and had a mess about tweaking it too, good stuff :)
Offline saidbakr
  • Freelance web developer.
« Reply #13 on: November 25, 2019, 01:31:21 pm »
It might be better if the text on the middle of the right side not centered. i.e aligned to right horizontally and middle vertically.
Best Regards
Said Bakr.
Offline rayzer
  • Graphics n Stuff
« Reply #14 on: December 02, 2019, 06:49:56 am »
cool wallpaper i found, gave it a bit of the pep treatment. darkened it down a bit too
