Author Topic: Cloning Hard drives refresher course  (Read 2767 times)
Re: Cloning Hard drives refresher course
« Reply #30 on: March 23, 2019, 02:54:10 pm »
The bs=1M would have helped (a lot) and obviously copying between SSD's is going to be much faster than between HDD's (specially if they're both on SATA).
'dd' is a terrific utility .. right up until the first time you make a syntax mistake .. from that point on you'll cack your pants every time you use it.
« Last Edit: March 23, 2019, 03:00:00 pm by PCNetSpec »
