Author Topic: AMD Vega series driver  (Read 4075 times)
Re: AMD Vega series driver
« Reply #45 on: March 21, 2019, 02:06:01 pm »
Yeah I got it wont be long
More haste less speed :)
« Reply #46 on: March 21, 2019, 02:22:20 pm »
inxi is already installed in 18.10 here's the output as requested
xubuntu@xubuntu:~/Desktop$ inxi -F
System:
  Host: xubuntu Kernel: 4.18.0-10-generic x86_64 bits: 64
  Desktop: Xfce 4.13.2 Distro: Ubuntu 18.10 (Cosmic Cuttlefish)
Machine:
  Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
  serial: <root required>
  Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <root required>
  UEFI [Legacy]: American Megatrends v: F3 date: 12/24/2018
CPU:
  Topology: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics
  bits: 64 type: MT MCP L2 cache: 2048 KiB
  Speed: 1420 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1420 2: 1471
  3: 1437 4: 1424 5: 1420 6: 1423 7: 1420 8: 1420
Graphics:
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  driver: amdgpu v: kernel
  Display: x11 server: X.Org 1.20.1 driver: amdgpu,ati
  unloaded: fbdev,modesetting,vesa resolution: 1920x1080~50Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.26.0 4.18.0-10-generic LLVM 7.0.0)
  v: 4.5 Mesa 18.2.2
Audio:
  Device-1: AMD driver: snd_hda_intel
  Device-2: AMD driver: snd_hda_intel
  Sound Server: ALSA v: k4.18.0-10-generic
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:41:3c:91
Drives:
  Local Storage: total: 469.42 GiB used: 1.40 GiB (0.3%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB
  ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler G3
Partition:
  ID-1: / size: 2.92 GiB used: 92.9 MiB (3.1%) fs: overlay dev: ERR-102
Sensors:
  System Temperatures: cpu: 37.9 C mobo: N/A gpu: amdgpu temp: 37 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 251 Uptime: 4m Memory: 5.83 GiB used: 871.0 MiB (14.6%)
  Shell: bash inxi: 3.0.24
« Reply #47 on: March 21, 2019, 02:26:58 pm »
Don't know if you expect this but xubuntu uses Parole as it's media player and it's playing video perfectly and sound working :)
« Reply #48 on: March 21, 2019, 02:34:33 pm »
Further to my last post VLC still crashes when I try to open a .mkv and gives the following error when I try to open a mp4
Your input can't be opened:
VLC is unable to open the MRL 'file:///media/xubuntu/597656ff-7c9c-427e-b55f-c464d6475e64/home/grant/Videos/we-will.mp4'. Check the log for details.
Parole reports a gstreamer backend error with the .mp4
« Reply #49 on: March 21, 2019, 04:16:12 pm »
At least it's using amdgpu (the correct) graphics driver.
I wonder if amdgpu-pro would make any difference ? .. wanna try it (tomorrow, whilst I build the ISO) ?
« Reply #50 on: March 21, 2019, 04:19:30 pm »
Yeah I'll try anything just tell me what you want me to do :)
« Reply #51 on: March 21, 2019, 04:21:08 pm »
I'll post instructions later .. I'm currently reading is
https://www.reddit.com/r/Ubuntu/comments/85vav4/how_i_installed_ubuntu_1804_with_ryzen_2200g/
Seems there are a LOT of stability issues with these AMD Rave Ridge setups in Linux that I'm trying to get my head around .. but it's all pointless unless we can get the system to use amdgpu first (as that's the correct driver, and the only way to get things like HDMI, etc.).
« Last Edit: March 21, 2019, 04:33:36 pm by PCNetSpec »
« Reply #52 on: March 21, 2019, 09:59:55 pm »
Can you (from within Peppermint) post the output from
dpkg -l | grep linux-firmware
and any output from:
sudo update-initramfs -uk all
« Reply #53 on: March 22, 2019, 04:16:30 am »
System spec from 18.04-2 as requested
ubuntu@ubuntu:~$ inxi -Fz
System:
  Host: ubuntu Kernel: 4.18.0-15-generic x86_64 bits: 64
  Desktop: Gnome 3.28.3 Distro: Ubuntu 18.04.2 LTS (Bionic Beaver)
Machine:
  Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
  Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter>
CPU:
  Speed: 1492 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1584 2: 1580
  3: 1460 4: 1591 5: 1502 6: 1495 7: 1575 8: 1591
Graphics:
  Device-1: AMD Vega [Radeon Vega 8 Mobile] driver: amdgpu v: kernel
  Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
  Sound Server: ALSA v: k4.18.0-15-generic
Network:
  driver: r8169
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 469.49 GiB used: 417.7 MiB (0.1%)
  ID-2: /dev/sda type: USB vendor: HP model: c485w size: 3.73 GiB
Partition:
  ID-1: / size: 2.92 GiB used: 417.7 MiB (14.0%) fs: overlay source: ERR-102
Sensors:
  Missing: Required tool sensors not installed. Check --recommends
Info:
  Processes: 291 Uptime: 5m Memory: 5.83 GiB used: 1.15 GiB (19.7%)
  Shell: bash inxi: 3.0.32
ubuntu@ubuntu:~$
« Reply #54 on: March 22, 2019, 04:21:38 am »
grant@Grant-Linux ~ $ dpkg -l | grep linux-firmware
ii  linux-firmware                            1.178                                           all          Firmware for Linux kernel drivers
grant@Grant-Linux ~ $ sudo update-initramfs -uk all
[sudo] password for grant:
update-initramfs: Generating /boot/initrd.img-5.0.2-050002-generic
update-initramfs: Generating /boot/initrd.img-4.18.0-16-generic
update-initramfs: Generating /boot/initrd.img-4.15.0-46-generic
update-initramfs: Generating /boot/initrd.img-4.15.0-43-generic
« Reply #55 on: March 22, 2019, 08:52:40 am »
Okay I've PM'd you a link to download a new ISO from my ReadyNAS
Can you use it to create a LiveUSB, boot to it, then post me the output from:
DO NOT INSTALL IT YET.
« Reply #56 on: March 22, 2019, 09:27:28 am »
BTW, here's the checksums if you want them
Peppermint-9-20190322-amd64.iso
md5sum: 7e6732a6c7a0b8cca4087dba307b7f26
sha256sum: f041565251a20b07a28ebc6bdebe8457145acc5db7316f5f470d19767ed65239
« Reply #57 on: March 22, 2019, 10:07:38 am »
As requested
System:    Host: peppermint Kernel: 4.18.0-16-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: desktop System: Gigabyte product: B450M DS3H serial: N/A
           Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: N/A
CPU:       Quad core AMD Ryzen 5 2400G with Radeon Vega Graphics (-MT-MCP-)
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1419 MHz 2: 1419 MHz 3: 1419 MHz
           4: 1427 MHz 5: 1432 MHz 6: 1576 MHz 7: 1446 MHz 8: 1481 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
           drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa)
           Resolution: 1920x1080@50.00hz
           OpenGL: renderer: AMD RAVEN (DRM 3.26.0, 4.18.0-16-generic, LLVM 7.0.0)
           version: 4.5 Mesa 18.2.8
Audio:     Card-1 Advanced Micro Devices [AMD] Device 15e3 driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Device 15depeppermint@peppermint ~ $ inxi -Fz
           cache: 2048 KB
           Sound: Advanced Linux Sound Architecture v: k4.18.0-16-generic
Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169
Drives:    HDD Total Size: 504.0GB (0.6% used)
           ID-1: /dev/nvme0n1 model: CT500P1SSD8 size: 500.1GB
           ID-2: USB /dev/sda model: DataTraveler_G3 size: 3.9GB
Partition: ID-1: / size: 3.0G used: 72M (3%) fs: overlay dev: N/A
           ID-2: swap-1 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-3: swap-2 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
           ID-4: swap-3 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram2
           ID-5: swap-4 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram3
           ID-6: swap-5 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram4
           ID-7: swap-6 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram5
           ID-8: swap-7 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram6
           ID-9: swap-8 size: 0.39GB used: 0.00GB (0%) fs: swap dev: /dev/zram7
Sensors:   System Temperatures: cpu: 16.8C mobo: N/A gpu: 31.0
Info:      Processes: 258 Uptime: 2 min Memory: 783.6/5970.7MB
           driver: r8169
« Reply #58 on: March 22, 2019, 10:29:04 am »
Okay it now seems as though we have amdgpu.
Up to you if you wanna reinstall with this ISO .. if you do, make SURE you boot to a Live Session and have an active internet connection before you click the "Install Peppermint" icon on the desktop.
(the reason is I haven't replaced the files in the /pool directory on the ISO yet .. so you'll need an active internet connection during the install if it needs to get GRUB)
« Reply #59 on: March 22, 2019, 11:15:22 am »
Ok Mark thanks
I still have a few issues I'd like to mention before I commit to install
There's no improvement to video playback in Media player if anything it's worse in as much as its stuttery in small screen as well as full screen where it was only stuttery in full screen before, but that said we have sound, The good news is it all seems to work perfectly in Parole for some reason, youtube videos play perfect.
Also my desktop is way oversize now and I can't see the Menu or panel but I'm sure we'll get over that
Many thanks
