Author Topic: AMD Vega series driver  (Read 3755 times)
Re: AMD Vega series driver
« Reply #30 on: March 20, 2019, 05:35:48 pm »
Sorry Graeme, didn't get much of a chance to research this today .. I'll try get onto it tomorrow (hopefully).
I **really** want to find an answer to this, it might be a nice inclusion for PM10 if we can reliably backport it from 19.04.
« Last Edit: March 20, 2019, 05:38:35 pm by PCNetSpec »
Online emegra
  • Peppermint version(s): Peppermint 9 64bit
« Reply #31 on: March 20, 2019, 05:56:31 pm »
Don't worry Mark I can hang on to it a bit longer the guy's not pushing me for it back, it would be nice if I can hand it over to him with everything working well and if it helps Peppermint all the better :)
« Reply #32 on: March 21, 2019, 12:22:18 pm »
what's the output from
lspci -vnn | grep -i vga
Online emegra
« Reply #33 on: March 21, 2019, 12:46:30 pm »
Output as requested
grant@Grant-Linux ~ $ lspci -vnn | grep -i vga
07:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] [1002:15dd] (rev c6) (prog-if 00 [VGA controller])
« Reply #34 on: March 21, 2019, 12:59:18 pm »
What's the output from
dpkg -l | grep linux-firmware
and can you run:
cat /var/log/Xorg.0.log > ~/Desktop/Xorg.0.log
the host the Xorg.0.log file that appeared on your desktop online somewhere and provide a link to it
« Last Edit: March 21, 2019, 01:05:18 pm by PCNetSpec »
Online emegra
« Reply #35 on: March 21, 2019, 01:11:54 pm »
Hoping I did that paste right let me know :)
grant@Grant-Linux ~ $ dpkg -l | grep linux-firmware
ii  linux-firmware                            1.178                                           all          Firmware for Linux kernel drivers
https://pastebin.com/YfrJTAuc
« Reply #36 on: March 21, 2019, 01:24:35 pm »
Have you still got nomodeset manually added as a kernel boot parameter ?
Online emegra
« Reply #37 on: March 21, 2019, 01:34:27 pm »
No I removed it
« Reply #38 on: March 21, 2019, 01:37:33 pm »
When ? .. when did it become no longer necessary ?
Are you up for trying an 18.10 distro, such as Xubuntu 18.10 .. just as a LiveUSB so we can see the inxi output (after installing inxi of course) ?
If that works, and you have this PC for a day or two, I'm up for building you a custom ISO with the HWE pre-installed as a test (and possibly a solution).
« Last Edit: March 21, 2019, 01:42:02 pm by PCNetSpec »
Online emegra
« Reply #39 on: March 21, 2019, 01:54:52 pm »
I removed it after we installed the 5 series kernel and it boots fine in the 4.18 I've never tried it with the 4.15 kernel so far
Yeah we can do that I'll go set it up now
Online emegra
« Reply #40 on: March 21, 2019, 01:59:31 pm »
I'm downloading xubuntu 18.04 now I'll be about 15 mins by the time I download & install then boot up
Online emegra
« Reply #41 on: March 21, 2019, 02:01:57 pm »
Damn I've just noticed I'm downloading 18.04 will I change it to 18.10 ?
« Reply #42 on: March 21, 2019, 02:02:39 pm »
Okey dokey :)
No real need to "install" it yet, just boot to a Live session, install inxi, and post the output.
Yeah .. needs to be 18.10
http://releases.ubuntu.com/18.10/ubuntu-18.10-desktop-amd64.iso
« Last Edit: March 21, 2019, 02:04:20 pm by PCNetSpec »
Online emegra
« Reply #43 on: March 21, 2019, 02:03:53 pm »
Ok I have 18.04 downloaded and 18.10 downloading do you want to wait for 18.10 or will I go with 18.04 ?
« Reply #44 on: March 21, 2019, 02:04:44 pm »
NEEDS to be 18.10
Although it'd also be nice to test 18.04.2
(but must be the .2 or higher version)
because that also uses the 4.18 kernel from the HWE .. so it'd be good to see if that works if 18.10 does .. then if 18.04.2 doesn't but 18.10 does, I can try figure out what's different in a VM.
Did that make sense ?
« Last Edit: March 21, 2019, 02:10:21 pm by PCNetSpec »
