Author Topic: AMD Vega series driver  (Read 3795 times)
Online emegra
Re: AMD Vega series driver
« Reply #15 on: March 19, 2019, 07:08:35 am »
Thanks pin I got it burning it now :)
Online emegra
« Reply #16 on: March 19, 2019, 07:21:43 am »
I'm unable to install inxi unable to locate package
[code]ubuntu@ubuntu:~$ sudo apt-get update && sudo apt-get install inxi
Ign:1 cdrom://Ubuntu 19.04 _Disco Dingo_ - Alpha amd64 (20190318) disco InRelease
Hit:2 cdrom://Ubuntu 19.04 _Disco Dingo_ - Alpha amd64 (20190318) disco Release
Hit:3 http://archive.ubuntu.com/ubuntu disco InRelease
Hit:4 http://security.ubuntu.com/ubuntu disco-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu disco-updates InRelease
Reading package lists... Done
Building dependency tree
E: Unable to locate package inxi
« Last Edit: March 19, 2019, 07:38:58 am by emegra »
« Reply #17 on: March 19, 2019, 08:15:39 am »
Download it from here
http://cz.archive.ubuntu.com/ubuntu/pool/universe/i/inxi/inxi_3.0.32-1-1_all.deb
place that file in your home folder, then run
sudo apt-get install ~/inxi_3.0.32-1-1_all.deb
Online emegra
« Reply #18 on: March 19, 2019, 08:21:33 am »
ubuntu@ubuntu:~$ inxi -F
System:
  Host: ubuntu Kernel: 5.0.0-7-generic x86_64 bits: 64 Desktop: Gnome 3.32.0
  Distro: Ubuntu 19.04 (Disco Dingo)
Machine:
  Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
  serial: <root required>
  Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <root required>
  UEFI [Legacy]: American Megatrends v: F3 date: 12/24/2018
CPU:
  Topology: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics
  bits: 64 type: MT MCP L2 cache: 2048 KiB
  Speed: 1523 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1463 2: 1420
  3: 1433 4: 1536 5: 1430 6: 1473 7: 1429 8: 1595
Graphics:
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  driver: amdgpu v: kernel
  Display: x11 server: X.Org 1.20.4 driver: amdgpu,ati
  unloaded: fbdev,modesetting,vesa resolution: 1920x1080~50Hz
  Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
  Device-1: AMD driver: snd_hda_intel
  Device-2: AMD driver: snd_hda_intel
  Sound Server: ALSA v: k5.0.0-7-generic
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:41:3c:91
Drives:
  Local Storage: total: 471.28 GiB used: 430.3 MiB (0.1%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB
  ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0
  ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler G3
Partition:
  ID-1: / size: 2.91 GiB used: 430.3 MiB (14.4%) fs: overlay source: ERR-102
Sensors:
  Missing: Required tool sensors not installed. Check --recommends
Info:
  Processes: 272 Uptime: 55m Memory: 5.83 GiB used: 1.17 GiB (20.0%)
  Shell: bash inxi: 3.0.32
ubuntu@ubuntu:~$
« Last Edit: March 19, 2019, 08:23:18 am by emegra »
« Reply #19 on: March 19, 2019, 09:47:34 am »
See that's what I was expecting .. amdgpu as the driver instead of the framebuffer driver you're currently getting in Peppermint.
I'll keep hunting, but are you up for testing the 5.0 kernel in Peppermint ?
Online emegra
« Reply #20 on: March 19, 2019, 09:52:51 am »
I had a feeling that's where you were going with this
Yeah I'm up for it :)
Just as a point of interest Ubuntu 19.04 booted and run no problem without nomodeset, unfortunately I can't test video playback as there seems to be no codecs installed
« Reply #21 on: March 19, 2019, 10:31:06 am »
Okay then, in Peppermint run these commands in sequence:
mkdir ~/kernel-5.0.2
cd ~/kernel-5.0.2
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.0.2/linux-headers-5.0.2-050002_5.0.2-050002.201903131832_all.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.0.2/linux-headers-5.0.2-050002-generic_5.0.2-050002.201903131832_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.0.2/linux-image-unsigned-5.0.2-050002-generic_5.0.2-050002.201903131832_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.0.2/linux-modules-5.0.2-050002-generic_5.0.2-050002.201903131832_amd64.deb
sudo dpkg -i *.deb
once finished, REBOOT (you may need to disable secureboot in your BIOS)
Once rebooted, post the output from
Remember, if it won't boot you should still be able to choose the 4.18 kernel from the GRUB menu.
Online emegra
« Reply #22 on: March 19, 2019, 10:44:32 am »
Output as requested
grant@Grant-Linux ~ $ inxi -Fz
System:    Host: Grant-Linux Kernel: 5.0.2-050002-generic x86_64 bits: 64
Machine:   Device: desktop System: Gigabyte product: B450M DS3H serial: N/A
           Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: N/A
CPU:       Quad core AMD Ryzen 5 2400G with Radeon Vega Graphics (-MT-MCP-)
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1351 MHz 2: 1351 MHz 3: 1767 MHz
           4: 2012 MHz 5: 2972 MHz 6: 2970 MHz 7: 1364 MHz 8: 1408 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
           drivers: fbdev,ati (unloaded: modesetting,vesa,radeon)
           Resolution: 1920x1080@77.00hz
           OpenGL: renderer: llvmpipe (LLVM 7.0, 128 bits) version: 3.3 Mesa 18.3.3
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
           Card-2 Advanced Micro Devices [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k5.0.2-050002-generic
Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169
           IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 500.1GB (6.6% used)
           ID-1: /dev/nvme0n1 model: CT500P1SSD8 size: 500.1GB
Partition: ID-1: / size: 182G used: 31G (18%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: No active sensors found. Have you configured your sensors yet? mobo: N/A
Info:      Processes: 248 Uptime: 2 min Memory: 704.9/5968.1MB
Online emegra
« Reply #23 on: March 19, 2019, 11:40:50 am »
It booted up fine but it's made no perceivable difference to the video playback, but that said I can now boot without nomodeset
« Reply #24 on: March 19, 2019, 01:00:35 pm »
Hmm, still on the fbdev driver and llvmpipe ???.. still looking.
Online emegra
« Reply #25 on: March 19, 2019, 01:13:45 pm »
Hope you don't nind if I throw a wobbler here but I've just noticed that running the 5 series kernel borks the Windows VM with this messageKernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall virtualbox-dkms package and load the kernel module by executing
'modprobe vboxdrv'
as root.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
even booting back into 4.18 or 4.15 doesn't fix the problem I had to completely uninstall all Virtualbox packages then reinstall Virtualbox from scratch to get it working again is this likely to be an issue even if we get video playback working right ?
« Reply #26 on: March 19, 2019, 01:41:04 pm »
What happens if you install the 19.04 firmware
http://cz.archive.ubuntu.com/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.178_all.deb
then reboot.
After doing so, can you post
again.
VM's **may** need to be rebuilt (or more likely vbox itself) .. but we'll get to that later, as I'm not even 100% sure we need to keep the 5.0 kernel yet.
« Last Edit: March 19, 2019, 01:44:29 pm by PCNetSpec »
Online emegra
« Reply #27 on: March 19, 2019, 02:15:52 pm »
As requested
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 3825 MHz 2: 3810 MHz 3: 1528 MHz
           4: 1528 MHz 5: 2186 MHz 6: 2190 MHz 7: 1550 MHz 8: 1599 MHz
           driver: r8169
Drives:    HDD Total Size: 500.1GB (8.0% used)
Partition: ID-1: / size: 182G used: 38G (22%) fs: ext4 dev: /dev/nvme0n1p5
Info:      Processes: 243 Uptime: 9 min Memory: 1277.3/5968.1MB
Online emegra
« Reply #28 on: March 20, 2019, 06:37:09 am »
Sorry Mark just realised I didn't fully answer you question on your last post
It made no perceivable difference, I've also realised I've got no sound output through HDMI,  Pulseaudio appears to be detecting it but there's no output, this PC is connected to a TV monitor so If I understand correctly I should be getting sound through the TV speakers, I've tried every setting possible in Pulseaudio but I'm getting nothing
« Last Edit: March 20, 2019, 06:57:21 am by emegra »
« Reply #29 on: March 20, 2019, 06:45:02 am »
That will also be down to its not using the amdgpu driver.
I'm looking for a way to 'force' amdgpu if we can't get it to switch automatically .. still looking.
