Author Topic: AMD Vega series driver  (Read 4382 times)
« on: March 18, 2019, 12:23:18 pm »
Hi guys
I've just installed PM9 on a friends PC and I'm having issues with graphics, to begin with I had to set the nomodeset boot parameter permanent to get it to boot, but even when booted the graphics aren't quite right, ie I cant get full screen video in SM player.
This is what I get
and VLC instantly crashess when I try to run a .mkv, Media player will run a video in full screen but it.s very stuttery, I'm sure this is a graphics driver issue but there's no additional drivers being offered, this is a brand new PC and there may not be a Linux driver for this GPU, I'm hoping I'm wrong
Here's the system specs
grant@Grant-Linux ~ $ inxi -F
System:    Host: Grant-Linux Kernel: 4.15.0-46-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: desktop System: Gigabyte product: B450M DS3H serial: N/A
           Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: N/A
           UEFI [Legacy]: American Megatrends v: F3 date: 12/24/2018
CPU:       Quad core AMD Ryzen 5 2400G with Radeon Vega Graphics (-MT-MCP-)
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1480 MHz 2: 1442 MHz 3: 1632 MHz
           4: 1589 MHz 5: 2742 MHz 6: 2942 MHz 7: 1421 MHz 8: 1463 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
           drivers: fbdev,ati (unloaded: modesetting,vesa,radeon)
           Resolution: 1920x1080@77.00hz
           OpenGL: renderer: llvmpipe (LLVM 7.0, 128 bits) version: 3.3 Mesa 18.2.2
Audio:     Card-1 Advanced Micro Devices [AMD] Device 15e3 driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Device 15de
           Sound: Advanced Linux Sound Architecture v: k4.15.0-46-generic
Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169
           IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:41:3c:91
Drives:    HDD Total Size: 504.0GB (6.3% used)
           ID-1: /dev/nvme0n1 model: CT500P1SSD8 size: 500.1GB
           ID-2: USB /dev/sda model: DataTraveler_G3 size: 3.9GB
Partition: ID-1: / size: 182G used: 30G (18%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 26.0C mobo: N/A
Info:      Processes: 247 Uptime: 4:02 Memory: 4398.9/5970.9MB
grant@Grant-Linux ~ $ lshw --display
Any help would be much appreciated
Re: AMD Vega series driver
« Reply #1 on: March 18, 2019, 12:45:45 pm »
I gather the AMD Ryzen 5 2400G requires kernel >= 4.17 to function properly, try switching to the hwe-18.04 which will pull in the 4.18 kernel and graphics stack:
sudo apt-get install --install-recommends linux-generic-hwe-18.04 xserver-xorg-hwe-18.04
then REBOOT.
After rebooting:-
a) check you're on the 4.18 kernel with
uname -a
b) see if graphics are working better .. and post the output from
again.
« Last Edit: March 18, 2019, 01:09:27 pm by PCNetSpec »
« Reply #2 on: March 18, 2019, 01:15:40 pm »
Hi Mark thanks for your help4.18
 I did as you suggested and sadly it's not improved the graphics at all I'm now definitely on the 4.18 kernel
grant@Grant-Linux ~ $ uname -a
Linux Grant-Linux 4.18.0-16-generic #17~18.04.1-Ubuntu SMP Tue Feb 12 13:35:51 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
and here's the specs as requested
grant@Grant-Linux ~ $ inxi -Fz
System:    Host: Grant-Linux Kernel: 4.18.0-16-generic x86_64 bits: 64 Desktop: N/A
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1973 MHz 2: 2022 MHz 3: 1386 MHz
           4: 1421 MHz 5: 2408 MHz 6: 2301 MHz 7: 1421 MHz 8: 1414 MHz
           Sound: Advanced Linux Sound Architecture v: k4.18.0-16-generic
           driver: r8169
           IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 504.0GB (6.5% used)
Partition: ID-1: / size: 182G used: 31G (18%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 16.8C mobo: N/A
Info:      Processes: 232 Uptime: 8 min Memory: 747.6/5970.7MB
Many thanks
« Reply #3 on: March 18, 2019, 01:37:24 pm »
does running
sudo update-pciids
then rebooting make any difference ?
« Reply #4 on: March 18, 2019, 01:53:34 pm »
According to this
http://ubuntuhandbook.org/index.php/2019/01/install-mesa-18-2-8-ppa-ubuntu-18-04-18-10/
Add the new Vega M, Vega 10, and Vega 20 PCI IDs
you may need an updated version of mesa ( >= 18.2.8 )
Can you post the output from
glxinfo | grep "OpenGL version"
whilst I test the version in X-Swat ( 18.3.3 )
« Last Edit: March 18, 2019, 01:55:56 pm by PCNetSpec »
« Reply #5 on: March 18, 2019, 02:08:35 pm »
ok updating pclids made no difference
here's the output
grant@Grant-Linux ~ $ sudo update-pciids
[sudo] password for grant:
Downloaded daily snapshot dated 2019-03-16 03:15:01
Here's the output you requested
grant@Grant-Linux ~ $ glxinfo | grep "OpenGL version"
OpenGL version string: 3.1 Mesa 18.2.2
« Reply #6 on: March 18, 2019, 02:10:27 pm »
Okay try this
sudo add-apt-repository ppa:ubuntu-x-swat/updates
sudo apt-get update
sudo apt-get upgrade
then REBOOT.
After rebooting:-
a) check if graphics are better
b) post the output from
dpkg -l | grep mesa
If that worked, it may be a good idea to now disable the x-swat PPA ;)
« Reply #7 on: March 18, 2019, 02:43:51 pm »
Thanks for the help, the PC in question is in my work office so I wont be able to follow your instructions until the morning now but I'll try to do it first thing and get back to you
Many thanks
« Reply #8 on: March 18, 2019, 03:00:21 pm »
Okay Graeme .. please do let me know though :)
« Reply #9 on: March 19, 2019, 04:15:05 am »
Ok Mark I followed your instructions unfortunately no difference to report :(
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1414 MHz 2: 1355 MHz 3: 2968 MHz
           4: 2963 MHz 5: 1351 MHz 6: 1351 MHz 7: 1351 MHz 8: 1350 MHz
           OpenGL: renderer: llvmpipe (LLVM 7.0, 128 bits) version: 3.3 Mesa 18.3.3
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
           Card-2 Advanced Micro Devices [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
           driver: r8169
Info:      Processes: 252 Uptime: 3 min Memory: 707.4/5970.7MB
OpenGL version string: 3.1 Mesa 18.3.3
grant@Grant-Linux ~ $ dpkg -l | grep mesa
ii  libegl-mesa0:amd64                    18.3.3-1ubuntu1~18.04~ppa1                      amd64        free implementation of the EGL API -- Mesa vendor library
ii  libegl1-mesa:amd64                    18.3.3-1ubuntu1~18.04~ppa1                      amd64        transitional dummy package
ii  libgl1-mesa-dri:amd64                 18.3.3-1ubuntu1~18.04~ppa1                      amd64        free implementation of the OpenGL API -- DRI modules
ii  libgl1-mesa-dri:i386                  18.3.3-1ubuntu1~18.04~ppa1                      i386         free implementation of the OpenGL API -- DRI modules
ii  libgl1-mesa-glx:amd64                 18.3.3-1ubuntu1~18.04~ppa1                      amd64        transitional dummy package
ii  libgl1-mesa-glx:i386                  18.3.3-1ubuntu1~18.04~ppa1                      i386         transitional dummy package
ii  libglapi-mesa:amd64                   18.3.3-1ubuntu1~18.04~ppa1                      amd64        free implementation of the GL API -- shared library
ii  libglapi-mesa:i386                    18.3.3-1ubuntu1~18.04~ppa1                      i386         free implementation of the GL API -- shared library
ii  libglu1-mesa:amd64                    9.0.0-2.1build1                                 amd64        Mesa OpenGL utility library (GLU)
ii  libglu1-mesa:i386                     9.0.0-2.1build1                                 i386         Mesa OpenGL utility library (GLU)
ii  libglx-mesa0:amd64                    18.3.3-1ubuntu1~18.04~ppa1                      amd64        free implementation of the OpenGL API -- GLX vendor library
ii  libglx-mesa0:i386                     18.3.3-1ubuntu1~18.04~ppa1                      i386         free implementation of the OpenGL API -- GLX vendor library
ii  libwayland-egl1-mesa:amd64            18.3.3-1ubuntu1~18.04~ppa1                      amd64        transitional dummy package
ii  mesa-utils                            8.4.0-1                                         amd64        Miscellaneous Mesa GL utilities
« Reply #10 on: March 19, 2019, 04:37:13 am »
run:
dmesg > ~/Desktop/dmesg.txt
then look through the file that just appeared on your desktop called "dmesg.txt"
host it somewhere like:-
http://www.tinyupload.com/
and provide me a link to it.
Meanwhile I'll keep digging :)
« Reply #11 on: March 19, 2019, 05:34:32 am »
http://s000.tinyupload.com/?file_id=50713959014986196208
If it's any help I tried an mp4 and it works fine in SM Player, VLC & Media Player no visible problem,
The file I've been testing so far (the one I'm having problems with)  is a .MKV which works fine in my other PC's and which doesn't have nearly as much horse power as this thing.
« Reply #12 on: March 19, 2019, 05:44:40 am »
Any chance you can download the 19.04 daily ISO and try it as a LiveUSB .. then install inxi in it
sudo apt-get update && sudo apt-get install inxi
then post the output from
from it.
« Reply #13 on: March 19, 2019, 06:10:23 am »
Where do I get the 19.04 build ?
« Reply #14 on: March 19, 2019, 07:05:43 am »
