Author Topic: [solved]No sound after kernel update  (Read 691 times)
Offline darknet
  • /home/darknet
  • Peppermint version(s): Peppermint 10 respin 64-bit
« on: March 18, 2019, 01:20:00 am »
I've installed kernel 4.18.0-16-generic rebooted my machine but now I am stuck with "Dummy Sound problem"
I tried
sudo apt-get remove --purge alsa-base
sudo apt-get remove --purge pulseaudio
sudo apt-get install alsa-base
sudo apt-get install pulseaudio
sudo alsa force-reload
Still dummy sound issue.
darknetmatrix@darknetmatrix-HP-Z400-Workstation ~ $ inxi -f
CPU:       Quad core Intel Xeon W3565 (-MT-MCP-) cache: 8192 KB
           clock speeds: max: 3193 MHz 1: 1628 MHz 2: 1604 MHz 3: 1631 MHz
           4: 1670 MHz
           CPU Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov
           constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts ept est
           flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
           monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt
           pse pse36 pti rdtscp rep_good sep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
           stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
darknetmatrix@darknetmatrix-HP-Z400-Workstation ~ $ inxi -F
System:    Host: darknetmatrix-HP-Z400-Workstation Kernel: 4.18.0-16-generic x86_64
           bits: 64
Machine:   Device: desktop System: Hewlett-Packard product: HP Z400 Workstation serial: N/A
           Mobo: Hewlett-Packard model: 0B4Ch v: D serial: N/A
           BIOS: Hewlett-Packard v: 786G3 v03.15 date: 10/29/2010
           clock speeds: max: 3193 MHz 1: 1790 MHz 2: 1709 MHz 3: 1804 MHz
           4: 1920 MHz
Graphics:  Card: NVIDIA GK208B [GeForce GT 710]
           drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: GeForce GT 710/PCIe/SSE2 version: 4.6.0 NVIDIA 390.116
Network:   Card: Broadcom and subsidiaries NetXtreme BCM5764M Gigabit Ethernet PCIe
           driver: tg3
           IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: 78:ac:c0:b8:49:72
Drives:    HDD Total Size: 2060.4GB (2.5% used)
           ID-1: /dev/sda model: SPCC_Solid_State size: 60.0GB
           ID-2: /dev/sdb model: WDC_WD20EFRX size: 2000.4GB
Partition: ID-1: / size: 55G used: 8.0G (16%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 1.8T used: 31G (2%) fs: ext4 dev: /dev/sdb2
           ID-3: swap-1 size: 10.49GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 200 Uptime: 10 min Memory: 1009.8/9974.3MB
« Last Edit: March 18, 2019, 01:41:30 am by darknet »
Re: No sound after kernel update
« Reply #1 on: March 18, 2019, 01:29:41 am »
Hi darknet,
Maybe try kernel 4.19.29 -- the 4.19 series is supposed to be an LTS release IIRC.
Re: [solved]No sound after kernel update
« Reply #3 on: March 18, 2019, 06:50:04 am »
Hi darknet,
Glad I could help solve your issue.  8)
