Author Topic: blank screen after grub menu (SOLVED)  (Read 606 times)
« on: March 16, 2019, 06:15:55 am »
Hi guys
A friend asked me to install Peppermint on his new pc currently running Windows 10, he need Windows & Excel for specific business software so I've installed it alongside Windows 10 and it's so far working fine except I need to run the nomodeset boot parameter every time at boot if not the screen just blanks out after the grub menu, I suppose I could edit the /boot/grub/grub.cfg file, but I'm not sure that would be the right thing to do even if it worked, it's an AMD graphics card see system info below
grant@Grant-Linux ~ $ inxi -F
System:    Host: Grant-Linux Kernel: 4.15.0-46-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: desktop System: Gigabyte product: B450M DS3H serial: N/A
           Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: N/A
           UEFI [Legacy]: American Megatrends v: F3 date: 12/24/2018
CPU:       Quad core AMD Ryzen 5 2400G with Radeon Vega Graphics (-MT-MCP-)
           cache: 2048 KB
           clock speeds: max: 3600 MHz 1: 1418 MHz 2: 1526 MHz 3: 1784 MHz
           4: 1994 MHz 5: 1417 MHz 6: 1402 MHz 7: 1474 MHz 8: 1463 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
           drivers: ati,vesa (unloaded: modesetting,fbdev,radeon)
           Resolution: 1920x1080@0.00hz
           OpenGL: renderer: llvmpipe (LLVM 7.0, 128 bits) version: 3.3 Mesa 18.2.2
Audio:     Card-1 Advanced Micro Devices [AMD] Device 15e3 driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Device 15de
           Sound: Advanced Linux Sound Architecture v: k4.15.0-46-generic
Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169
           IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: b4:2e:99:41:3c:91
Drives:    HDD Total Size: 500.1GB (5.7% used)
           ID-1: /dev/nvme0n1 model: CT500P1SSD8 size: 500.1GB
Partition: ID-1: / size: 182G used: 27G (16%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 43.9C mobo: N/A
Info:      Processes: 226 Uptime: 10 min Memory: 685.8/5970.9MB
  TIA Graeme
« Last Edit: March 16, 2019, 09:38:11 am by emegra »
Re: blank screen after grub menu
« Reply #1 on: March 16, 2019, 06:42:05 am »
Hi!
I think you should actually do this on /etc/default/grub  and not on /boot/grub/grub.cfg
See here, https://askubuntu.com/questions/38780/how-do-i-set-nomodeset-after-ive-already-installed-ubuntu
« Reply #2 on: March 16, 2019, 09:37:50 am »
Thank you pin that sorted it :)
Re: blank screen after grub menu (SOLVED)
« Reply #3 on: March 16, 2019, 10:53:19 am »
You're more than welcome, glad its fixed  :)
