Author Topic: Desktop is Gray w/no icons  (Read 444 times)
Offline dougbkk
« on: March 16, 2019, 01:25:11 am »
Booted up my machine and my desktop wallpaper and icons are gone. I can't right click on the desktop either. Tried restarting and the problem persists.
Any help is much appreciated.
Re: Desktop is Gray w/no icons
« Reply #1 on: March 16, 2019, 02:21:35 am »
Hi
to get you back to the desktop try
Ctrl+Alt+F2
and then right after, don't wait
Ctrl+Alt+F7
« Reply #2 on: March 16, 2019, 01:35:32 pm »
What happens if you hit Ctrl+Alt+T, and when a terminal opens run:
nemo-desktop
