Author Topic: New Linux Kernel: The Big 5.0  (Read 2231 times)
Re: New Linux Kernel: The Big 5.0
« Reply #15 on: March 18, 2019, 12:48:59 pm »
There ya go then, set one of those up in the corner to display the startup screen permanently .. then when booting your PC, quickly glance over then back .. problem solved :)
« Reply #16 on: March 18, 2019, 04:40:43 pm »
 >:( Damn it!
... I couldn't resist  :D
Offline VinDSL
« Reply #17 on: March 18, 2019, 04:46:20 pm »
Poor soul... RCs are a sickness.
I was okay for awhile, but they're starting to take over my brain again   :)
« Reply #18 on: March 18, 2019, 04:48:43 pm »
Perhaps it's time to coin the Phrase
"Kernalitus" to go with "Hoppertitus"
« Reply #19 on: March 18, 2019, 04:52:56 pm »
 :D  :D
...I stayed away from it... for nearly two weeks, but... now I'm stuck again  :'(
EDIT: ok, I won't let this be stronger than me  :)
Booted back into the default 4.4.0-143 and removed all other kernels from the system. Kept one as fall back, 4.4.0-142.
EDIT 2: It makes life easier. Now, back at some other project...
« Last Edit: March 18, 2019, 05:09:29 pm by pin »
« Reply #20 on: March 18, 2019, 05:35:15 pm »
Yeah, seems necessary ..
Kernelephantiasis - A largely benign affliction characterised by the victims inability to stop voluntarily bloating their operating system with parasitic non-default kernels.
« Last Edit: March 20, 2019, 05:24:41 pm by PCNetSpec »
Offline VinDSL
« Reply #21 on: March 20, 2019, 03:25:41 am »
Got rid of Butter FS (I always forget to do  that) and about 70-80 other abandoned packages  8)
Knocked another 1/2 second off the boot time...
vindsl@Killerwatt ~ $ systemd-analyze time
Startup finished in 2.038s (kernel) + 1.284s (userspace) = 3.322s
graphical.target reached after 1.280s in userspace
vindsl@Killerwatt ~ $ systemd-analyze critical-chain |more
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @1.280s
└─udisks2.service @493ms +786ms
  └─basic.target @485ms
    └─sockets.target @485ms
      └─acpid.socket @485ms
        └─sysinit.target @482ms
          └─systemd-update-utmp.service @477ms +5ms
            └─systemd-tmpfiles-setup.service @466ms +8ms
              └─local-fs.target @466ms
                └─home.mount @460ms +6ms
                  └─systemd-fsck@dev-disk-by\x2duuid-f4c3bcf8\x2dc165\x2d47a3\x2da909\x2dead4a3877203.service @378ms +80ms
                    └─dev-disk-by\x2duuid-f4c3bcf8\x2dc165\x2d47a3\x2da909\x2dead4a3877203.device @377ms
vindsl@Killerwatt ~ $ sudo inxi -GMSfimsuxxxz -v 7
[sudo] password for vindsl:
System:    Host: Killerwatt Kernel: 5.0.0-7-generic x86_64 bits: 64 gcc: 8.3.0
           Console: tty 1 dm: lightdm Distro: Peppermint Nine
Machine:   Device: desktop System: Dell product: OptiPlex 7010 v: 01 serial: <filter>
           Mobo: Dell model: 0YXT71 v: A01 serial: <filter>
           UEFI: Dell v: A29 date: 06/28/2018
           Chassis: type: 3 serial: <filter>
CPU:       Quad core Intel Core i7-3770 (-MT-MCP-)
           arch: Ivy Bridge rev.9 cache: 8192 KB bmips: 27138
           clock speeds: min/max: 1600/3900 MHz 1: 1596 MHz 2: 1597 MHz 3: 1605 MHz
           4: 1596 MHz 5: 1600 MHz 6: 1600 MHz 7: 1600 MHz 8: 1598 MHz
           CPU Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush
           cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
           epb ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb
           ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae
           pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
           rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
           stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
           x2apic xsave xsaveopt xtopology xtpr
Memory:    Array-1 capacity: 32 GB devices: 4 EC: None
           Device-1: DIMM3 size: 2 GB speed: 1600 MT/s type: DDR3 (Synchronous)
           bus width: 64 bits
           manufacturer: Micron part: 8JTF25664AZ-1G6M1 serial: <filter>
           Device-2: DIMM1 size: 2 GB speed: 1600 MT/s type: DDR3 (Synchronous)
           bus width: 64 bits
           manufacturer: Hynix/Hyundai part: HMT325U6EFR8C-PB serial: <filter>
           Device-3: DIMM4 size: 2 GB speed: 1600 MT/s type: DDR3 (Synchronous)
           bus width: 64 bits
           Device-4: DIMM2 size: 2 GB speed: 1600 MT/s type: DDR3 (Synchronous)
           bus width: 64 bits
           Device-5: N/A size: N/A speed: N/A type: N/A
           bus width: N/A manufacturer: N/A part: N/A serial: N/A
           Device-6: N/A size: N/A speed: N/A type: N/A
Graphics:  Card: NVIDIA GK208B [GeForce GT 730] bus-ID: 01:00.0 chip-ID: 10de:1287
           Display Server: X.Org 1.19.6
           drivers: nvidia (unloaded: modesetting,fbdev,vesa)
           Resolution: 1920x1200@59.95hz
           OpenGL: renderer: GeForce GT 730/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.116 Direct Render: Yes
Audio:     Card-1 Intel 7 Series/C216 Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1e20
           Card-2 NVIDIA GK208 HDMI/DP Audio Controller
           driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0e0f
           Sound: Advanced Linux Sound Architecture v: k5.0.0-7-generic
Network:   Card: Intel 82541PI Gigabit Ethernet Controller
           driver: e1000 v: 7.3.21-k8-NAPI port: d000
           bus-ID: 02:02.0 chip-ID: 8086:107c
           IF: enp2s2 state: up speed: 1000 Mbps duplex: full mac: <filter>
           WAN IP: <filter>
           IF: enp2s2 ip-v4: <filter> ip-v6-link: <filter>
Drives:    HDD Total Size: 1320.3GB (0.5% used)
           ID-1: /dev/sda model: CT1000MX500SSD1 size: 1000.2GB
           serial: <filter> temp: 36C
           ID-2: /dev/sdb model: ST320LT009 size: 320.1GB
           serial: <filter> temp: 31C
           Optical-1: /dev/sr0 model: MATSHITA DVD-ROM SW420
           rev: D.02 dev-links: cdrom,dvd
           Features: speed: 48x multisession: yes
           audio: yes dvd: yes rw: none state: running
Partition: ID-1: / size: 20G used: 5.0G (27%) fs: ext4 dev: /dev/sda2
           label: Root uuid: 71243b7b-60f2-4d90-8282-271c159d1982
           ID-2: /boot/efi size: 300M used: 6.1M (3%) fs: vfat dev: /dev/sda1
           label: UEFI uuid: 2D36-30F3
           ID-3: /home size: 59G used: 449M (1%) fs: ext4 dev: /dev/sda3
           label: Home uuid: f4c3bcf8-c165-47a3-a909-ead4a3877203
           ID-4: swap-1 size: 0.54GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
           label: Swap uuid: d9aebe01-4915-4cdb-9693-e9ea05e51cef
RAID:      System: supported: N/A
           No RAID devices: /proc/mdstat, md_mod kernel module present
           Unused Devices: none
Unmounted: ID-1: /dev/sdb1 size: 0.10G fs: NTFS
           label: System Reserved uuid: F84CF3214CF2D8F8
           ID-2: /dev/sdb2 size: 319.97G fs: NTFS label: N/A uuid: 925EF5265EF503AF
Sensors:   System Temperatures: cpu: 31.0C mobo: N/A gpu: 0.0:40C
Info:      Processes: 216 Uptime: 9 min Memory: 735.5/7959.4MB
           Init: systemd v: 237 runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (sudo running in bash) inxi: 2.3.56
« Last Edit: March 20, 2019, 03:29:48 am by VinDSL, Reason: Addendum »
Offline VinDSL
« Reply #22 on: March 21, 2019, 05:02:46 am »
Did weekly updates, on my P7 Road Warrior, and The Big 5.0 came rolling in.  :)
╭─vindsl@Chi-You ~
╰─$ systemd-analyze time
Startup finished in 4.430s (firmware) + 1.425s (loader) + 3.347s (kernel) + 1.312s (userspace) = 10.515s
╭─vindsl@Chi-You ~
╰─$ systemd-analyze critical-chain
graphical.target @1.307s
└─multi-user.target @1.307s
  └─mintsystem.service @1.026s +280ms
    └─basic.target @963ms
      └─sockets.target @963ms
        └─acpid.socket @963ms
          └─sysinit.target @961ms
            └─systemd-update-utmp.service @914ms +3ms
              └─systemd-tmpfiles-setup.service @856ms +57ms
                └─local-fs.target @854ms
                  └─boot-efi.mount @823ms +30ms
                    └─systemd-fsck@dev-disk-by\x2duuid-EA02\x2d59E2.service @498ms +323ms
                      └─dev-disk-by\x2duuid-EA02\x2d59E2.device @498ms
╭─vindsl@Chi-You ~
╭─vindsl@Chi-You ~
╰─$ sudo inxi -CDGMSfimuxxxz
System:    Host: Chi-You Kernel: 5.0.0-8-generic x86_64 (64 bit gcc: 8.3.0)
           Desktop: N/A info: xfce4-panel dm: lightdm Distro: Peppermint Seven
Machine:   System: Dell (portable) product: Latitude E6430 v: 01 Chassis: type: 9
           Mobo: Dell model: N/A Bios: Dell v: A23 date: 11/30/2018
CPU:       Dual core Intel Core i7-3540M (-HT-MCP-) cache: 4096 KB bmips: 11961
           clock speeds: min/max: 1200/3700 MHz 1: 1196 MHz 2: 1199 MHz 3: 1210 MHz 4: 1228 MHz
           CPU Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc cpuid
           cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms est f16c flexpriority flush_l1d fpu
           fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep smep smx ss
           ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi
           vpid x2apic xsave xsaveopt xtopology xtpr
Memory:    Array-1 capacity: 16 GB devices: 2 EC: None
           Device-1: DIMM A size: 4 GB speed: 1600 MHz type: DDR3 (Synchronous)
           bus width: 64 bits manufacturer: Samsung part: M471B5173CB0-YK0 serial: 35102720
           Device-2: DIMM B size: 4 GB speed: 1600 MHz type: DDR3 (Synchronous)
           bus width: 64 bits manufacturer: Samsung part: M471B5173EB0-YK0 serial: 94A2057F
           Device-3: N/A size: N/A speed: N/A type: N/A bus width: N/A manufacturer: N/A part: N/A serial: N/A
           Device-4: N/A size: N/A speed: N/A type: N/A bus width: N/A manufacturer: N/A part: N/A serial: N/A
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:0166
           Display Server: X.org 1.19.6 drivers: (unloaded: fbdev,vesa)
           tty size: 151x43 Advanced Data: N/A for root
Network:   Card-1: Intel 82579LM Gigabit Network Connection (Lewisville)
           driver: e1000e v: 3.2.6-k port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502
           Card-2: Intel Wireless 7260 driver: iwlwifi bus-ID: 02:00.0 chip-ID: 8086:08b1
           WAN IP: <filter> IF: wlp2s0 ip-v4: <filter> ip-v6: <filter>
           IF: eno1 ip-v4: N/A ip-v6: N/A
Drives:    HDD Total Size: 570.1GB (4.5% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB serial: S2R5NB0HB27540R temp: 0C
           ID-2: /dev/sdb model: Hitachi_HTS72323 size: 320.1GB serial: 081006FC1400NEG6P7JD temp: 35C
Partition: ID-1: / size: 20G used: 6.0G (33%) fs: ext4 dev: /dev/sda6 uuid: 78aa9438-5bec-4c95-a1fe-f78d384264c8
           ID-2: /home size: 59G used: 18G (32%) fs: ext4 dev: /dev/sda7
           uuid: d4010a0b-d14f-422b-9aee-b5c1ebca8589
           ID-3: swap-1 size: 0.54GB used: 0.00GB (0%) fs: swap dev: /dev/sda8
           uuid: 46de3fd8-221d-4634-9270-b35aaa8633ed
╭─vindsl@Chi-You ~
Not bad, for a 'daily driver'...
Offline clatterfordslim
« Reply #23 on: May 01, 2019, 07:16:00 pm »
I'm currently on 5,0.10, though I am on my Elitebook 2540p with 90GB of SSD 1.8", Intel I7 dual core processor and 4GB of Ram. Now I have upgraded to kernel 5.0.10, you're right it boots in no time at all, I get to my login screen in around eight seconds, which ain't bad at all. I'm going to see which version I can put on my main rig later on today.  Here is the specs of this machine. I'm currently at work, on another night shift. Still this quiet time, enables me to go onto the Internet.  ;D
System:    Host: Elitebook Kernel: 5.0.10-050010-generic x86_64 bits: 64 gcc: 8.3.0
Machine:   Device: laptop System: Hewlett-Packard product: HP EliteBook 2540p serial: N/A
           Mobo: Hewlett-Packard model: 7008 v: KBC Version 38.34 serial: N/A
           BIOS: Hewlett-Packard v: 68CSU Ver. F.50 date: 07/08/2014
Battery    BAT0: charge: 41.9 Wh 100.0% condition: 41.9/41.9 Wh (100%)
           model: Hewlett-Packard Primary status: Full
CPU:       Dual core Intel Core i7 L 640 (-MT-MCP-)
           arch: Nehalem rev.5 cache: 4096 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8512
           clock speeds: max: 2134 MHz 1: 1362 MHz 2: 1426 MHz 3: 1335 MHz
           4: 1326 MHz
Graphics:  Card: Intel Core Processor Integrated Graphics Controller
           bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.6 ) driver: intel
           Resolution: 1280x800@59.98hz
           OpenGL: renderer: Mesa DRI Intel Ironlake Mobile
           version: 2.1 Mesa 18.2.8 Direct Render: Yes
Audio:     Card Intel 5 Series/3400 Series High Def. Audio
           Sound: Advanced Linux Sound Architecture v: k5.0.10-050010-generic
Network:   Card-1: Intel 82577LM Gigabit Network Connection
           driver: e1000e v: 3.2.6-k port: 5000 bus-ID: 00:19.0
           IF: enp0s25 state: down mac: <filter>
           Card-2: Intel Centrino Advanced-N 6200 driver: iwlwifi bus-ID: 43:00.0
Drives:    HDD Total Size: 90.0GB (10.6% used)
           ID-1: /dev/sda model: D2CSTK181A10 size: 90.0GB
Partition: ID-1: / size: 83G used: 9.0G (12%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 55.0C mobo: N/A
Repos:     Active apt sources in file: /etc/apt/sources.list
           deb http://archive.ubuntu.com/ubuntu bionic main restricted
           deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted
           deb http://archive.ubuntu.com/ubuntu bionic universe
           deb http://archive.ubuntu.com/ubuntu bionic-updates universe
           deb http://archive.ubuntu.com/ubuntu bionic multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-updates multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-security main restricted
           deb http://archive.ubuntu.com/ubuntu bionic-security universe
           deb http://archive.ubuntu.com/ubuntu bionic-security multiverse
           Active apt sources in file: /etc/apt/sources.list.d/peppermint.list
           deb http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic main
           deb http://ppa.launchpad.net/peppermintos/p9-respin/ubuntu bionic main
           Active apt sources in file: /etc/apt/sources.list.d/stebbins-ubuntu-handbrake-releases-bionic.list
           deb http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu bionic main
           Active apt sources in file: /etc/apt/sources.list.d/teejee2008-ubuntu-ppa-bionic.list
           deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic main
Info:      Processes: 196 Uptime: 18 min Memory: 627.5/3735.3MB
           Init: systemd runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.191) inxi: 2.3.56
But so is this Forum :)
Offline VinDSL
« Reply #24 on: May 01, 2019, 07:37:07 pm »
Nice!
Yeah, I've been happy with it, so far.  :)
« Reply #25 on: May 02, 2019, 12:49:58 am »
Am I alone using the 5.1 series?!
...just kidding, nice to see another "tester"  :)
« Reply #26 on: May 02, 2019, 06:59:21 am »
It's lonely out there ahead of the curve :)
« Reply #27 on: May 02, 2019, 11:48:16 am »
Indeed...
...but, there are plenty of us, is just that some are really shy  :D
