Author Topic: New to Peppermint have a couple of issues  (Read 906 times)
Offline bushblade
« on: March 14, 2019, 02:34:54 am »
Hi I just installed Peppermint 9 on my HP Pavillion G6 after the trackpad stopped working correctly after a recent update on Manjaro. I couldn't resolve the trackpad issue so decided to try Peppermint.
I'ts all working pretty well and was a painless install but I am having a couple of issues I hope someone can help with?
After the laptop suspends after closing the lid and is opened again I lose the mouse pointer, it's still there as I can see when it hovers over menu items or icons with the hover effect but I can't see the pointer and have to reboot via terminal.
The other issue is I installed Visual Studio Code from the repos but the version in the repos had a lot of issues (mainly with shell detection). So I downloaded the .deb from the website which is working as expected. I did uninstall the version from the repos first but the menu entry is still there for it. So how do I remove the menu entry? Should it not be removed when the package is uninstalled?
Thanks in advance
Will
Offline bushblade
Re: New to Peppermint have a couple of issues
« Reply #1 on: March 14, 2019, 02:54:38 am »
Sorry just a couple more questions:
Why is the version of node js in the repos at 8.10 when current lts is 10.15 and current 11.11?
Also npm version is at 3.5.2 when latest is 6.9?
Offline bushblade
« Reply #2 on: March 14, 2019, 06:45:10 am »
Ok I solved the leftover menu entries but I found another issue that I can't figure out. The laptop does not lock on suspend or on lid close despite the settings set to do just that, the only way I can lock the device is using ctrl + alt + l
I don't lose the cursor after locking like this only when I close the lid.
« Reply #3 on: March 14, 2019, 08:27:32 am »
The lock screen in the power manager is designed to use a screensaver (such as xscreensaver) to lock the screen buy we don't have a screensaver OOTB.
You can either
a) install one, such as xscreensaver, then set that to lock the screen.
or
b) create a symlink at /usr/bin/xscreensaver that points at i3lock-fancy (the screenlock we use) by running these 2 commands in sequence
cd /usr/binthen
sudo ln -s /usr/lib/i3lock-fancy/i3lock-fancy xscreensaver
« Last Edit: March 14, 2019, 08:29:29 am by PCNetSpec »
Offline bushblade
« Reply #4 on: March 14, 2019, 09:41:06 am »
Thanks for the reply, I went for the latter option using i3lock but it still does not lock, and my cursor still disappears.
« Reply #5 on: March 14, 2019, 10:46:51 am »
You'll need to explain that a bit better ? .. how are you putting it into suspend ?
Have you got "Lock screen when system is going for sleep" selected in the power manager ?
Offline bushblade
« Reply #6 on: March 14, 2019, 11:12:13 am »
Yes I do, I am closing the lid to suspend.
« Reply #7 on: March 14, 2019, 12:11:32 pm »
Maybe you should try switching power manager from xfce4-power-manager to mate-power-manager
See here:
https://forum.peppermintos.com/index.php/topic,7244.msg74105.html#msg74105
Offline bushblade
« Reply #8 on: March 14, 2019, 12:14:31 pm »
Any suggestions as to how to not lose the cursor after closing the lid?
Offline bushblade
« Reply #9 on: March 14, 2019, 04:24:20 pm »
Ok so switching to the mate power manager fixes loses the mouse pointer after a suspend but I still can't get it to lock when I close the lid.
« Reply #10 on: March 15, 2019, 01:22:59 pm »
What's the the output from:
ls -l /usr/bin/xscreensaver
Offline bushblade
« Reply #11 on: March 15, 2019, 04:08:42 pm »
ls: cannot access '/usr/bin/xscreensaver': No such file or directory
Offline bushblade
« Reply #12 on: March 16, 2019, 05:33:37 am »
I removed xscreensaver after it did not work with xfce4-power-manager, I added it back again now to try it with mate-power-manager but it still does not lock and my mouse pointer vanishes again now every time I close the screen.
Offline bushblade
« Reply #13 on: March 17, 2019, 07:38:05 am »
I've switched to Linux Mint XFCE and don't have the issues there despite it also using xfce-power-manager and no xscreensaver, it does lock on lid close and no loss off mouse pointer.
