Author Topic: UPDate ERROR any help Please [Solved]  (Read 1474 times)
Offline FERE
  • Peppermint version(s): DISTRIB_RELEASE=9
« on: March 07, 2019, 10:42:53 pm »
Good Day
I am very very New with Peppermint   and it looks like i Finally Found the Best Distro for me
but i get this Error always when updating   please look
« Last Edit: March 08, 2019, 10:37:11 pm by zebedeeboss »
Re: UPDate ERROR any help Please
« Reply #1 on: March 07, 2019, 11:18:05 pm »
Is this an installed system or a live session? The reason I ask is, you usually don't use the CD ROM after the system is installed, you get everything from the online software repositories.
As for those warnings in general, you can get those occasionally, they typically indicate that a repository is temporarily down, and trying again later usually works.
Offline FERE
« Reply #2 on: March 08, 2019, 12:30:48 am »
No it is not a Live CD  i have Installed Peppermint  on a SSD
other then this repository ERROR  im good
many thanks
« Reply #3 on: March 08, 2019, 12:45:26 am »
Good Day
Hi FERE,
Open synaptic package manager. Find the repository section and then untick any item that shows the CDRom - There should only be one entry. Let it refresh and that error should go away.
« Reply #4 on: March 08, 2019, 01:10:26 am »
Follow zebs suggestion.
If for some reason you still have a problem after doing so, please post the output of
cat /etc/apt/sources.list.dand, possibly
cat /etc/apt/trusted.gpg.d
Offline FERE
« Reply #5 on: March 08, 2019, 02:59:15 am »
Good Day
Hi FERE,
HI Zeb
Thanks for helping me out
but i am very new to Linux and did not find what you are talking about      So i made some Pictures
Many thanks
Offline FERE
« Reply #6 on: March 08, 2019, 03:01:14 am »
Hi
Thank you
But I didnt get to far with these commands  ;D
minnts@minnts-System-Product-Name ~ $ cat /etc/apt/sources.list.d
cat: /etc/apt/sources.list.d: Is a directory
minnts@minnts-System-Product-Name ~ $ cat /etc/apt/trusted.gpg.d
cat: /etc/apt/trusted.gpg.d: Is a directory
« Reply #7 on: March 08, 2019, 03:02:13 am »
Hi
2nd picture clearly says  CDRom
Remove the tick please
« Reply #8 on: March 08, 2019, 04:30:05 am »
Hi
Thank you
Sorry, just replace cat with ls  :(
But, first do what zeb asked  ;)
« Reply #9 on: March 08, 2019, 05:00:19 am »
Okay what's happening here is - for some reason the CDROM didn't get disabled as a repository post installation, so let's disable it manually.
Go to:-
Menu > Settings > Software & Updates
When that opens, select the "Other Software" tab
Now REMOVE (untick) the tick from "cdrom:[Peppermint 9 (20180621) - Release amd64]/bionic"
Enter your password when prompted and hit the "OK" button.
Then click the "Close" button.
Then when prompted, the "Reload" button.
You should now be all set and no longer receive that error.
« Last Edit: March 08, 2019, 05:04:17 am by PCNetSpec »
Offline FERE
« Reply #10 on: March 08, 2019, 05:45:52 am »
Go to:-
Thanks I did as you told me and also rebooted still got this
i dont think its a big deal as long is everything els is working correctly
many thanks
Offline rayzer
  • Graphics n Stuff
« Reply #11 on: March 08, 2019, 06:46:57 am »
disable the pipelight repos too by the looks of things, same tab as cdrom
« Reply #12 on: March 08, 2019, 10:56:42 am »
Yeah, remove the tick from the two lines that contain "pipelight"
Or even better, highlight the top line that contains "pipelight" and click the "Remove" button.
(which should remove BOTH lines)
It's been years since pipelight was needed for anything, and the reason there's nothing in the PPA for 18.04 (hence the error).
« Last Edit: March 09, 2019, 04:47:44 am by PCNetSpec »
Offline FERE
« Reply #13 on: March 08, 2019, 09:02:07 pm »
@rayzer
@   PCNetSpec
Thanks guys it worked
Tell you a Little Secret
I have no Clue why i enabled them in the first Place
I thought by having all of them ticked   i wont miss out on any updates lol
thanks to all
Re: UPDate ERROR any help Please [Solved]
« Reply #14 on: March 08, 2019, 10:37:48 pm »
Hi FERE,
For future reference, could you please remember to mark the topic as [SOLVED] in the subject line of the original post. This will then help other users find answers to common problems. I've done this for you this time.  Many thanks   :)
