Author Topic: Joplin Notes  (Read 384 times)
Offline thohnhaus
Joplin Notes
« on: March 05, 2019, 10:55:04 pm »
Hi
Does anyone know how to install Joplin Notes in Peppermint?
It was easy to install in my, “play Linux,( Fedora 29)” but I cannot figure out how to install it in Peppermint 9, which is my, “work,” Linux
Thanks
Re: Joplin Notes
« Reply #1 on: March 05, 2019, 11:07:31 pm »
Guess you've tried the instructions here, https://github.com/laurent22/joplin/blob/master/README.md ?!
« Last Edit: March 06, 2019, 12:14:28 am by pin »
Re: Joplin Notes
« Reply #2 on: March 06, 2019, 02:15:21 am »
Go down to the link Pin gave you.  Scroll down and click the Linux Download Icon and it will dl an Appimage.
You may need to check permissions has the tick box in executable.
Double click it in file manager. Say yes to add to Menu - Job done.
